Das gibt es doch nicht. Ich habe nämlich eine Kopie erhalten. Und der Empfänger war auch richtig: caladia@cad.de
Vielleicht hilft aber das weiter: Die gesamte MNU per Kopieren und einfügen. Welche Zeilen muß ich jetzt umschreiben, und welche Dateien löschen.
// AutoCAD LT Menu
// Based on AutoCAD Menu
// Feb. 5, 2001
// Copyright (C) 1986, 1987, 1988, 1989, 1990, 1991, 1992, 1994, 1996,
// 1997, 1998, 1999, 2000 by Autodesk, Inc.
// Permission to use, copy, modify, and distribute this software
// for any purpose and without fee is hereby granted, provided that
// the above copyright notice appears in all copies and that both
// the copyright notice and the limited warranty and restricted rights
// notice below appear in all supporting documentation.
// AUTODESK, INC. PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
// AUTODESK, INC. SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
// MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC.
// DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
// UNINTERRUPTED OR ERROR FREE.
// Use, duplication, or disclosure by the U.S. Government is subject to
// restrictions set forth in FAR 52.227-19 (Commercial Computer
// Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
// (Rights in Technical Data and Computer Software), as applicable.
// Default AutoCAD LT NAMESPACE declaration:
***MENUGROUP=ACLT
// Begin Digitizer Button Menus
***BUTTONS1
// Simple + button
// if a grip is hot bring up the Grips Cursor Menu (POP 500), else send a carriage return
// If the SHORTCUTMENU sysvar is not 0 the first item (for button 1) is NOT USED.
$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,5),GRIP_),$P0=ACLT.GRIPS $P0=*);
$P0=SNAP $p0=*
^C^C
^B
^O
^G
^D
^E
^T
***BUTTONS2
// Shift + button
$P0=SNAP $p0=*
***BUTTONS3
// Control + button
***BUTTONS4
// Control + shift + button
// Begin System Pointing Device Menus
***AUX1
// Simple button
// If the SHORTCUTMENU sysvar is not 0 the first item (for button 1, the "right button")
// is NOT USED.
$P0=SNAP $p0=*
^C^C
^B
^O
^G
^D
^E
^T
***AUX2
// Shift + button
$P0=SNAP $p0=*
$P0=SNAP $p0=*
***AUX3
// Control + button
$P0=SNAP $p0=*
***AUX4
$P0=SNAP $p0=*
// Begin Pull-down Menus
***POP0
**SNAP
// Shift-right-click if using the default AUX2 and/or BUTTONS2
// menus.
[&Objektfang-Cursormenü]
ID_Tracking [S&pur]_tracking
ID_From [&Von]_from
ID_MnPointFi [->Punkt&filter]
ID_PointFilx [.X].X
ID_PointFily [.Y].Y
ID_PointFilz [.Z].Z
ID_PointFixy [.XY].XY
ID_PointFixz [.XZ].XZ
ID_PointFiyz [<-.YZ].YZ
ID_OsnapEndp [&Endpunkt]_endp
ID_OsnapMidp [&Mittelpunkt]_mid
ID_OsnapInte [&Schnittpunkt]_int
ID_OsnapAppa [&Angenomm. Schnittpunkt]_appint
ID_OsnapCent [&Zentrum]_cen
ID_OsnapQuad [&Quadrant]_qua
ID_OsnapTang [Tan&gente]_tan
ID_OsnapPerp [Lo&t]_per
ID_OsnapNode [P&unkt]_nod
ID_OsnapInse [&Basispunkt]_ins
ID_OsnapNear [Näc&hster]_nea
ID_OsnapNone [&Keiner]_non
ID_Osnap [&Objektfang...]'_osnap
***POP1
**FILE
ID_MnFile [&Datei]
ID_New [&Neu...\tStrg+N]^C^C_new
ID_Open [Ö&ffnen...\tStrg+O]^C^C_open
ID_DWG_CLOSE [Sc&hließen]^C^C_close
ID_Save [Speiche&rn\tStrg+S]^C^C_qsave
ID_Saveas [Speichern &unter...]^C^C_saveas
ID_ETransmit [&eTransmit]^C^C_etransmit
ID_Publish [Im &Web publizieren...]^C^C_publishtoweb
ID_Export [E&xportieren...]^C^C_export
ID_PlotSetup [Seite &einrichten...]^C^C_pagesetup
ID_PlotMgr [Plot-&Manager...]^C^C_plottermanager
ID_PlotStyMgr [Plotst&il-Manager...]^C^C_stylesmanager
ID_Preview [Plot-&Voransicht]^C^C_preview
ID_Print [&Plot...\tStrg+P]^C^C_plot
ID_MnDrawing [->&Dienstprogramme]
ID_Audit [&Prüfung]^C^C_audit
ID_Recover [&Wiederherstellen...]^C^C_recover
ID_BupdateA [Blocksymbole &aktualisieren]^C^C_blockicon
ID_Purge [<-&Bereinigen...]^C^C_purge
ID_SendMail [&Senden...]
ID_Props [&Zeichnungseigenschaften...]^C^C_dwgprops
ID_MRU [Zuletzt geöffnete Datei]
ID_APP_EXIT [&Beenden]^C^C_quit
***POP2
**EDIT
ID_MnEdit [&Bearbeiten]
ID_U [&Rückgängig\tStrg+Z]_u
ID_Redo [Z&lösch\tStrg+Y]^C^C_mredo 1
ID_Cutclip [&Ausschneiden\tStrg+X]^C^C_cutclip
ID_Copyclip [&Kopieren\tStrg+C]^C^C_copyclip
ID_Copybase [Kopieren mit &Basispunkt]^C^C_copybase
ID_Copylink [Kopie &verknüpfen]^C^C_copylink
ID_Pasteclip [&Einfügen\tStrg+V]^C^C_pasteclip
ID_Pastebloc [Als Blo&ck einfügen]^C^C_pasteblock
ID_Pastehlnk [Als H&yperlink einfügen]^C^C_pasteashyperlink
ID_Pasteorig [Mit Original-Koordinaten ein&fügen]^C^C_pasteorig
ID_Pastesp [&Inhalte einfügen...]^C^C_pastespec
ID_Erase [Lösc&hen\tEntf]^C^C_erase
ID_SelAll [&Alle wählen\tStrg+A]^C^C_ai_selall
ID_Links [&OLE-Verknüpfungen...]^C^C_olelinks
ID_TextFind [&Suchen...]^C^C_find
***POP3
**VIEW
ID_MnView [&Ansicht]
ID_Redrawall [&Neuzeichnen]'_redrawall
ID_Regen [&Regenerieren]^C^C_regen
ID_RegenAll [&Alles regenerieren]^C^C_regenall
ID_MnZoom [->&Zoom]
ID_ZoomRealt [E&chtzeit]'_zoom ;
ID_ZoomPrevi [&Vorher]'_zoom _p
ID_ZoomWindo [&Fenster]'_zoom _w
ID_ZoomDynam [&Dynamisch]'_zoom _d
ID_ZoomScale [&Zoomfaktor]'_zoom _s
ID_ZoomCente [&Mitte]'_zoom _c
ID_ZoomIn [V&ergrößern]'_zoom 2x
ID_ZoomOut [Ve&rkleinern]'_zoom .5x
ID_ZoomAll [&Alles]'_zoom _all
ID_ZoomExten [<-&Grenzen]'_zoom _e
ID_MnPan [->&Pan]
ID_Pan [&Echtzeit]'_pan
ID_PanPick [&Punkt]'_-pan
ID_PanLeft [&Links]^P_ai_pan left ^P
ID_PanRight [&Rechts]^P_ai_pan right ^P
ID_PanUp [Nach &oben]^P_ai_pan up ^P
ID_PanDown [<-Nach &unten]^P_ai_pan down ^P
ID_Dsviewer [Übersi&chtsfenster]'_dsviewer
ID_MnTiledVi [->Ansichts&fenster]
ID_Ai_tiledv [&Benannte Ansichtsfenster...]^C^C_+vports 1
ID_VportsSav [N&eue Ansichtsfenster...]^C^C_+vports 0
ID_VportsSin [&1 Ansichtsfenster]^C^C$M=$(if,$(eq,$(getvar,tilemode),1),^C^C_-vports _si,^C^C_-vports)
ID_Vports2 [&2 Ansichtsfenster]^C^C_-vports _2
ID_Vports3 [&3 Ansichtsfenster]^C^C_-vports _3
ID_Vports4 [&4 Ansichtsfenster]^C^C_-vports _4
ID_VportsJoi [<-$(if,$(eq,$(getvar,tilemode),0),~)&Verbinden]^C^C_-vports _j
ID_Ddview [&Benannte Ausschnitte...]^C^C_view
ID_MnViewpoi [->$(if,$(and,$(eq,$(getvar,tilemode),0),$(eq,$(getvar,cvport),1)),~,)&3D-Ansichten]
ID_Ddvpoint [&Ansichtspunkt-Vorgaben...]^C^C_ddvpoint
ID_VpointTri [Ansichtspun&kt]^C^C_vpoint ;
ID_MnPlanView [->Drauf&sicht]
ID_PlanCurre [Aktuelles B&KS]^C^C_plan ;
ID_PlanWorld [&Welt]^C^C_plan _w
ID_PlanUCS [<-&Benanntes BKS]^C^C_plan _u
ID_VpointTop [O&ben]^C^C_-view _top
ID_VpointBot [&Unten]^C^C_-view _bottom
ID_VpointLef [&Links]^C^C_-view _left
ID_VpointRig [&Rechts]^C^C_-view _right
ID_VpointFro [&Vorne]^C^C_-view _front
ID_VpointBac [&Hinten ]^C^C_-view _back
ID_VpointSW [&ISO-Ansicht SW]^C^C_-view _swiso
ID_VpointSE [IS&O-Ansicht SO]^C^C_-view _seiso
ID_VpointNE [ISO-Ansi&cht NO]^C^C_-view _neiso
ID_VpointNW [<-ISO-Ansich&t NW]^C^C_-view _nwiso
ID_Dview [$(if,$(and,$(eq,$(getvar,tilemode),0),$(eq,$(getvar,cvport),1)),~,)D&ynamische 3D-Ansicht]^C^C_dview
ID_Hide [&Verdecken]^C^C_hide
[->$(if,$(and,$(eq,$(getvar,tilemode),0),$(eq,$(getvar,cvport),1)),~,)Sc&hattieren]
ID_Shade0 [256 &Farben]^C^C_shadedge 0 _shade
ID_Shade1 [256 Farben, mit &Kanten]^C^C_shadedge 1 _shade
ID_Shade2 [16 Farben, &verdeckt]^C^C_shadedge 2 _shade
ID_Shade3 [<-16 Farben, &gefüllt]^C^C_shadedge 3 _shade
ID_MnDisplay [->Anzei&ge]
ID_MnUCSicon [->BKS-&Symbol]
ID_UcsiconOn [$(if,$(and,$(getvar,ucsicon),1),!.)&Ein]$M=$(if,$(and,$(getvar,ucsicon),1),^C^C_ucsicon _off,^C^C_ucsicon _on)
ID_UcsiconOr [$(if,$(and,$(getvar,ucsicon),2),!.)&Ursprung]$M=$(if,$(and,$(getvar,ucsicon),2),^C^C_ucsicon _no,^C^C_ucsicon _or)
ID_UcsiconPr [<-&Eigenschaften]^C^C_ucsicon _p
ID_MnAttribu [->&Attributanzeige]
ID_AttdispNo [$(if,$(eq,$(getvar,attmode),1),!.)&Normal]'_attdisp _n
ID_AttdispOn [$(if,$(eq,$(getvar,attmode),2),!.)&Ein]'_attdisp _on
ID_AttdispOf [<-$(if,$(eq,$(getvar,attmode),0),!.)&Aus]'_attdisp _off
ID_Textscr [<-&Textfenster\tF2]'_textscr
ID_Toolbar [&Werkzeugkästen...]^C^C_toolbar
***POP4
**INSERT
ID_MnInsert [&Einfügen]
ID_Ddinsert [Blo&ck...]^C^C_insert
ID_Xattach [&XRef...]^C^C_xattach
ID_MnLayout [->&Layout]
ID_NewLayout [&Neues Layout]^C^C_layout _new
ID_TmplLayou [Layout von &Vorlage...]^C^C_layout _template
ID_LayoutWiz [<-&Layout-Assistent]^C^C_layoutwizard
ID_Wmfin [&WMF...]^C^C_wmfin
ID_Insertobj [&OLE-Objekt...]^C^C_insertobj
ID_MARKUP [&Markierung...]^C^C_rmlin
ID_Xref [X&Ref-Manager...]^C^C_xref
ID_Hyperlink [&Hyperlink...\tStrg+K]^C^C_hyperlink
***POP5
**FORMAT
ID_MnFormat [&Format]
ID_Layer [L&ayer...]'_layer
ID_Ddcolor [&Farbe...]'_color
ID_Linetype [&Linientyp...]'_linetype
ID_Linewt [Linien&stärke...]'_lweight
ID_Style [&Textstil...]'_style
ID_Ddim [&Bemaßungsstil...]'_dimstyle
ID_PlotStyle [$(if,$(eq,$(getvar,pstylemode),1),~,)&Plotstil...]^C^C_plotstyle
ID_Ddptype [Pun&ktstil...]'_ddptype
ID_Units [&Einheiten...]'_units
ID_Thickness [&Objekthöhe]'_thickness
ID_Limits [L&imiten]'_limits
ID_Ddrename [&Umbenennen...]^C^C_rename
***POP6
**TOOLS
ID_MnTools [Ex&tras]
ID_Today [A&ktuell]^C^C_Today
ID_PointA [A&utodesk Point A]^C^C_^C^C_browser http://pointa.autodesk.com
ID_MeetNow [&Besprechung]^C^C_MeetNow
ID_Spell [&Rechtschreibung]'_spell
ID_Qselect [&Schnellauswahl...]^C^C_qselect
ID_MnOrder [->An&zeigereihenfolge]
ID_DrawordeF [Ganz &oben]^C^C^P_ai_draworder _f ^P
ID_DrawordeB [Ganz &unten]^C^C^P_ai_draworder _b ^P
ID_DrawordeA [Nach &vorne]^C^C^P_ai_draworder _a ^P
ID_DrawordeU [<-Nach &hinten]^C^C^P_ai_draworder _u ^P
ID_Inquiry [->Abfra&ge]
ID_Dist [&Abstand]'_dist
ID_Area [&Fläche]^C^C_area
ID_Massprop [&Region/Masseneigenschaften]^C^C_massprop
ID_List [A&uflisten]^C^C_list
ID_Id [&ID Punkt]'_id
ID_Time [<-&Zeit]'_time
ID_Ddattext [Attributse&xtraktion...]^C^C_attext
ID_Revdate [Zeit und &Datum]^C^C_revdate
ID_Revcloud [Revisions&wolke]^C^C_revcloud
ID_Modify [$(if,$(and,$(getvar,opmstate),1),!.)Eigensc&haften\tStrg+1]$M=$(if,$(and,$(getvar,opmstate),1),^C^C_propertiesclose,^C^C_properties)
ID_Content [$(if,$(and,$(getvar,adcstate),1),!.)Auto&CAD DesignCenter\tStrg+2]$M=$(if,$(and,$(getvar,adcstate),1),'_adcclose,'_adcenter)
ID_Script [Skr&ipt ausführen...]'_script
ID_Dducs [Benanntes BKS&...]^C^C_+ucsman 0
ID_UcsOrtho [->&Orthogonales BKS]
ID_Dducsp [&BKS-Ausrichtung...]^C^C_+ucsman 1
ID_UcsTop [&Oben]^C^C_ucs _g _t
ID_UcsBottom [&Unten]^C^C_ucs _g _b
ID_UcsLeft [&Links]^C^C_ucs _g _l
ID_UcsRight [&Rechts]^C^C_ucs _g _r
ID_UcsFront [&Vorne]^C^C_ucs _g _f
ID_UcsBack [<-&Hinten]^C^C_ucs _g _ba
ID_UcsMove [BKS &verschieben]^C^C_ucs _move
ID_MnUCS [->N&eues BKS]
ID_UcsWorld [&Welt]^C^C_ucs _w
ID_UcsObject [&Objekt]^C^C_ucs _ob
ID_UcsFace [&Fläche]^C^C_ucs _fa
ID_UcsView [A&nsicht]^C^C_ucs _v
ID_UcsOrigin [&Ursprung]^C^C_ucs _o
ID_UcsZAxVec [Z-A&chse]^C^C_ucs _zaxis
ID_Ucs3point [&3 Punkte]^C^C_ucs _3
ID_UcsXAxRot [&X]^C^C_ucs _x
ID_UcsYAxRot [&Y]^C^C_ucs _y
ID_UcsZAxRot [<-&Z]^C^C_ucs _z
ID_MnWizard [->&Assistenten]
ID_AddPlotter [&Plotter hinzufügen...]^C^C^P_ai_startapp addplwiz.exe ^P
ID_AddPlStyle [Plot&stiltabelle hinzufügen....]^C^C^P_ai_startapp styshwiz.exe ^P
ID_PenSetting [$(if,$(eq,$(getvar,pstylemode),1),&Farbabhängige Plotstiltabelle hinzufügen...,&Benannte Plotstiltabelle hinzufügen...)]^C^C_r14penwizard
ID_CreateLayout [Layout &erstellen...]^C^C_layoutwizard
ID_ImpPlotSet [<-Ploteinstellungen &importieren...]^C^C_pcinwizard
ID_Ddrmodes [Entwur&fseinstellungen...]'_dsettings
ID_QkGroup [Gru&ppieren]^C^C_-pkfstgroup; * ;
ID_QkUnGroup [&Gruppierung aufheben]^C^C_qkungroup
ID_GroupDlg [Gruppen&manager...]^C^C_pkfstgroup
ID_MnTablet [->&Tablett]
ID_TabletOn [$(if,$(getvar,tabmode),!.)&Ein]^C^C_tablet _on
ID_TabletOff [$(if,$(eq,$(getvar,tabmode),0),!.)&Aus]^C^C_tablet _off
ID_TabletCal [&Kalibrieren]^C^C_tablet _cal
ID_TabletCfg [<-K&onfigurieren]^C^C_tablet _cfg
ID_Customize [->An&passen]
ID_Menuload [&Menüs...]^C^C_menuload
ID_CToolbar [&Werkzeugkästen...]^C^C_+customize 1
ID_CKeyboard [<-&Tastatur...]^C^C_+customize 3
ID_Preferenc [Optio&nen...]^C^C_options
***POP7
**DRAW
ID_MnDraw [&Zeichnen]
ID_Line [&Linie]^C^C_line
ID_Ray [Stra&hl]^C^C_ray
ID_Xline [K&onstruktionslinie]^C^C_xline
ID_Dline [&Doppellinie]^C^C_dline
ID_Pline [&Polylinie]^C^C_pline
ID_3dpoly [&3D-Polylinie]^C^C_3dpoly
ID_Polygon [Pol&ygon]^C^C_polygon
ID_Rectang [&Rechteck]^C^C_rectang
ID_MnArc [->Bo&gen]
ID_Arc3point [&3 Punkte]^C^C_arc
ID_ArcStCeEn [&Startp, Mittelp, Endp]^C^C_arc \_c
ID_ArcStCeAn [S&tartp, Mittelp, Winkel]^C^C_arc \_c \_a
ID_ArcStCeLe [St&artp, Mittelp, Sehnenlänge]^C^C_arc \_c \_l
ID_ArcStEnAg [Sta&rtp, Endp, Winkel]^C^C_arc \_e \_a
ID_ArcStEnDi [Start&p, Endp, Richtung]^C^C_arc \_e \_d
ID_ArcStEnRa [Startp, &Endp, Radius]^C^C_arc \_e \_r
ID_ArcCeStEn [&Mittelp, Startp, Endp]^C^C_arc _c
ID_ArcCeStAn [M&ittelp, Startp, Winkel]^C^C_arc _c \\_a
ID_ArcCeStLe [Mitte&lp, Startp, Sehnenlänge]^C^C_arc _c \\_l
ID_ArcContin [<-&Weiter]^C^C_arc ;
ID_MnCircle [->&Kreis]
ID_CircleRad [Mittel, &Radius]^C^C_circle
ID_CircleDia [Mittel, &Durchm.]^C^C_circle \_d
ID_Circle2pt [&2 Punkte]^C^C_circle _2p
ID_Circle3pt [&3 Punkte]^C^C_circle _3p
ID_CircleTTR [&Tan, Tan, Radius]^C^C_circle _ttr
ID_CircleTTT [<-T&an, Tan, Tan]^C^C_circle _3p _tan \_tan \_tan \
ID_Donut [R&ing]^C^C_donut
ID_Spline [&Spline]^C^C_spline
ID_MnEllipse [->&Ellipse]
ID_EllipseCe [&Zentrum]^C^C_ellipse _c
ID_EllipseAx [&Achse, Endpunkt]^C^C_ellipse
ID_EllipseAr [<-&Bogen]^C^C_ellipse _a
ID_MnBlock [->&Block]
ID_Bmake [&Erstellen...]^C^C_block
ID_Base [&Basis]'_base
ID_Attdef [<-&Attribute...]^C^C_attdef
ID_MnPoint [->P&unkt]
ID_PointSing [Einzelner &Punkt]^C^C_point
ID_PointMult [Mehrere P&unkte]*^C^C_point
ID_Divide [&Teilen]^C^C_divide
ID_Measure [<-&Messen]^C^C_measure
ID_Bhatch [S&chraffur...]^C^C_bhatch
ID_Boundary [Umgren&zung...]^C^C_boundary
ID_Region [Regio&n]^C^C_region
ID_MnText [->Te&xt]
ID_Mtext [&Absatztext...]^C^C_mtext
ID_Dtext [<-&Einzeiliger Text]^C^C_dtext
***POP8
**DIMENSION
ID_MnDimensi [Be&maßung]
ID_Dimlinear [&Linear]^C^C_dimlinear
ID_Dimaligne [&Ausgerichtet]^C^C_dimaligned
ID_Dimordina [&Koordinatenbemaßung]^C^C_dimordinate
ID_Dimradius [&Radius]^C^C_dimradius
ID_Dimdiamet [&Durchmesser]^C^C_dimdiameter
ID_Dimangula [&Winkel]^C^C_dimangular
ID_Dimbaseli [&Basislinie]^C^C_dimbaseline
ID_Dimcontin [W&eiter]^C^C_dimcontinue
ID_Leader [&Führung]^C^C_qleader
ID_Tolerance [&Toleranz...]^C^C_tolerance
ID_Dimcenter [&Zentrumsmarke]^C^C_dimcenter
ID_Dimedito [Sc&hräg]^C^C_dimedit _o
ID_MnAlign [->Te&xt ausrichten]
ID_DimteditH [&Ausgangsposition]^C^C_dimedit _h
ID_DimteditA [&Winkel]^C^C_dimtedit \_a
ID_DimteditL [&Links]^C^C_dimtedit \_l
ID_DimteditC [&Zentriert]^C^C_dimtedit \_c
ID_DimteditR [<-&Rechts]^C^C_dimtedit \_r
ID_Ddim [St&il...]'_dimstyle
ID_Dimoverri [Übers&chreiben]^C^C_dimoverride
ID_DimstyleA [Akt&ualisieren]^C^C_-dimstyle _apply
ID_Dimreasso [&Bemaßungen erneut verknüpfen ]^C^C_dimreassociate
***POP9
**MODIFY
ID_MnModify [Ä&ndern]
ID_Modify [Eigens&chaften]^C^C_properties
ID_Matchprop [Eigenschaften an&passen]'_matchprop
ID_MnObject [->&Objekt]
ID_MnExterna [->&XRef]
ID_Xbind [<-&Binden...]^C^C_xbind
ID_Imagefram [&Bildrahmen]^C^C_imageframe
ID_Hatchedit [Schra&ffur...]^C^C_hatchedit
ID_Pedit [&Polylinie]^C^C_pedit
ID_Splinedit [&Spline]^C^C_splinedit
ID_MnAttribu [->&Attribut]
ID_AtteditSin [&Bearbeiten...]^C^C_attedit
ID_AtteditGlo [<-&Global bearbeiten]^C^C_-attedit
ID_Blockdsc [B&lockbeschreibung...]^C^C_block
ID_MnText [->&Text]
ID_Ddedit [&Bearbeiten...]^C^C_ddedit
ID_Scaletext [&Zoomfaktor]^C^C_scaletext
ID_Justifyte [<-<-&Ausrichten]^C^C_justifytext
ID_Erase [Lösc&hen]^C^C_erase
ID_Copy [&Kopieren]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_copy,^C^C_copy)
ID_Mirror [Spie&geln]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_mirror,^C^C_mirror)
ID_Offset [Versetze&n]^C^C_offset
ID_Array [&Reihe...]^C^C_array
ID_Move [&Schieben]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_move,^C^C_move)
ID_Rotate [&Drehen]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_rotate,^C^C_rotate)
ID_Scale [&Varia]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_scale,^C^C_scale)
ID_Stretch [S&trecken]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_stretch,^C^C_stretch)
ID_Lengthen [&Länge]^C^C_lengthen
ID_Trim [Stut&zen]^C^C_trim
ID_Extend [D&ehnen]^C^C_extend
ID_Break [&Bruch]^C^C_break
ID_Chamfer [&Fasen]^C^C_chamfer
ID_Fillet [&Abrunden]^C^C_fillet
ID_MnRegion [->Re&gion]
ID_Union [&Vereinigung]^C^C_union
ID_Subtract [Differen&z]^C^C_subtract
ID_Intersect [<-&Schnittmenge]^C^C_intersect
ID_Explode [&Ursprung]^C^C_explode
***POP10
**WINDOW
ID_MnWindow [Fen&ster]
ID_DWG_CLOSE [&Schließen]^C^C_close
ID_WINDOW_CLOSEALL [&Alle schließen]^C^C_closeall
ID_WinCas [Ü&berlappend]^C^C_syswindows;_cascade
ID_WinHor [&Untereinander]^C^C_syswindows;_hor
ID_WinVrt [&Nebeneinander]^C^C_syswindows;_vert
ID_WINDOW_ARRANGE [S&ymbole anordnen]^C^C_syswindows;_arrange
***POP11
**HELP
ID_MnHelp [&?]
ID_Help [&Hilfe\tF1]'_help
ID_ASSIST [&Aktive Hilfe]'_ASSIST
ID_Support [&Support Assistance]^C^C^P_ai_support_assistance ^P
ID_ProdSupp [&Produkt-Support auf Point A]^C^C^Pai_product_support ^P
ID_WhatsNew [&Neu in dieser Version]^C^C_WhatsNew
ID_AUGI [In&ternationale Benutzergruppe von Autodesk]^C^C_ai_browse augi.htm
ID_BuyOnline [&Online-Kauf]^C^C_buyonline
ID_About [&Info]'_about
// POP menus with a primary alias of POP500 and above do not appear in the customize
// menu list of menus that can be inserted into the main menu bar. All context
// menus should have primary aliases of POP500 and above.
***POP500
**GRIPS
// When a grip is hot, then display the following shortcut menu for grips. See also AUX1 menu.
[&Griffe-Cursormenü]
ID_Enter [Ei&ngabe];
ID_GripMove [S&chieben]_move
ID_GripMirro [S&piegeln]_mirror
ID_GripRotat [&Drehen]_rotate
ID_GripScale [&Varia]_scale
ID_GripStret [&Strecken]_stretch
ID_GripBase [B&asispunkt]_base
ID_GripCopy [&Kopieren]_copy
ID_GripRefer [$(if,$(or,$(eq,$(getvar,cmdnames),GRIP_SCALE),$(eq,$(getvar,cmdnames),GRIP_ROTATE)),,~)&Referenz]_reference
ID_GripUndo [R&ückgängig]_u
ID_Modify [&Eigenschaften]^C^C_properties
ID_GotoURL [&Gehe zu URL...]^C^C_gotourl
ID_GripExit [&Beenden]_exit
***POP501
**CMDEFAULT
[Kontextmenü für Standardmodus]
ID_CMNonLast [Wiederh&olen %s]^C^C;
ID_Cutclip [Aussch&neiden]^C^C_cutclip
ID_Copyclip [&Kopieren]^C^C_copyclip
ID_Pasteclip [&Einfügen]^C^C_pasteclip
ID_U [&Rückgängig]^C^C_u
ID_Redo [&Wiederherstellen]^C^C_mredo 1
ID_Pan [P&an]'_pan
ID_ZoomRealt [Zoo&m]'_zoom ;
ID_Filter [Sc&hnellauswahl...]^C^C_qselect
ID_Preferenc [O&ptionen...]^C^C_options
***POP502
**CMEDIT
[Kontextmenü für Bearbeitungsmodus]
ID_CMSelLast [Wiederh&olen %s]^C^C;
ID_Erase [&Löschen]^C^C_erase
ID_Move [&Verschieben]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_move,^C^C_move)
ID_Copy [&Auswahl kopieren]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_copy,^C^C_copy)
ID_Scale [Skalie&ren]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_scale,^C^C_scale)
ID_Deselectall [Aus&wahl aufheben]^C^C^P_ai_deselect ^P
ID_Filter [Schnella&uswahl...]^C^C_qselect
ID_Modify [E&igenschaften]^C^C_properties
***POP503
**CMCOMMAND
[Kontextmenü für Befehlsmodus]
ID_Enter [&Eingabe];
ID_Cancel [&Abbrechen]^C
ID_Pan [$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),ZOOM),~,)&Pan]'_pan
ID_ZoomRealt [$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),ZOOM),~,)&Zoom]'_zoom ;
***POP504
**OBJECTS_DIMENSION
[Kontextmenü für Bemaßungsobjekte]
ID_DimText [->Position Maßte&xt]
ID_DimAbove [Über M&aßlinie]^C^C_ai_dim_textabove
ID_DimTxtCen [&Zentriert]^C^C_ai_dim_textcenter
ID_DimHome [A&usgangsposition Text]^C^C_ai_dim_texthome
ID_DimTxtMove2 [&Nur Text verschieben]^C^C_aidimtextmove _2
ID_DimTxtMove1 [&Mit Führung verschieben]^C^C_aidimtextmove _1
ID_DimTxtMove0 [<-Mit &Bemaßungslinie verschieben]^C^C_aidimtextmove _0
ID_DimPrec [->Genau&igkeit]
ID_DimPrec0 [0]^C^C_aidimprec _0
ID_DimPrec1 [0.0]^C^C_aidimprec _1
ID_DimPrec2 [0.00]^C^C_aidimprec _2
ID_DimPrec3 [0.000]^C^C_aidimprec _3
ID_DimPrec4 [0.0000]^C^C_aidimprec _4
ID_DimPrec5 [0.00000]^C^C_aidimprec _5
ID_DimPrec6 [<-0.000000]^C^C_aidimprec _6
ID_DimSty1 [->Bem&.stil]
ID_DimSty2 [Als neuen &Stil speichern...]^C^C_aidimstyle _S
ID_DimSty3 [Bem.stil MRU1]^C^C_aidimstyle _1
ID_DimSty4 [Bem.stil MRU2]^C^C_aidimstyle _2
ID_DimSty5 [Bem.stil MRU3]^C^C_aidimstyle _3
ID_DimSty6 [Bem.stil MRU4]^C^C_aidimstyle _4
ID_DimSty7 [Bem.stil MRU5]^C^C_aidimstyle _5
ID_DimSty8 [Bem.stil MRU6]^C^C_aidimstyle _6
ID_DimSty9 [<-&Andere...]^C^C_aidimstyle _O
***POP505
**OBJECT_VIEWPORT
[Kontextmenü für Ansichtsfenster-Objekte]
ID_Vport_disp [->An&sichtsfenster anzeigen]
ID_Vport_dispon [&Ja]^C^C_-vports _on _p;;
ID_Vport_dispoff [<-&Nein]^C^C_-vports _off _p;;
ID_Vport_lock [->An&zeige gesperrt]
ID_Vport_lockon [&Ja]^C^C_-vports _lock _on _p;;
ID_Vport_lockoff [<-&Nein]^C^C_-vports _lock _off _p;;
ID_Vport_hide [->&Plot ausblenden]
ID_Vport_hideon [&Ja]^C^C_-vports _hide _on _p;;
ID_Vport_hideoff [<-&Nein]^C^C_-vports _hide _off _p;;
***POP506
**OBJECTS_XREF
[Kontextmenü für XREF-Objekte]
***POP507
**OBJECT_MTEXT
[Kontextmenü für MTEXT-Objekt]
ID_Mtedit [&Mtext bearbeiten...]^C^C_mtedit
***POP508
**OBJECT_TEXT
[Kontextmenü für TEXT-Objekt]
ID_Ddedit [&Text bearbeiten...]^C^C_ddedit
***POP509
**OBJECT_HATCH
[Kontextmenü für SCHRAFFUR-Objekt]
ID_Hatchedit [Schraffur bearbei&ten...]^C^C_hatchedit
***POP510
**OBJECT_LWPOLYLINE
[Kontextmenü für PLINIEN-Objekt]
ID_Pedit [&Polylinie bearbeiten]^C^C_pedit
***POP511
**OBJECT_SPLINE
[Kontextmenü für SPLINE-Objekt]
ID_Splinedit [&Spline bearbeiten]^C^C_splinedit
// Begin ToolBars
***TOOLBARS
**TB_DIMENSION
ID_TbDimensi [_Toolbar("Bemaßung", _Floating, _Hide, 100, 130, 1)]
ID_Dimlinear [_Button("Lineare Bemaßung", ICON_16_DIMLIN, ICON_16_DIMLIN)]^C^C_dimlinear
ID_Dimaligne [_Button("Ausgerichtete Bemaßung", ICON_16_DIMALI, ICON_16_DIMALI)]^C^C_dimaligned
ID_Dimordina [_Button("Koordinatenbemaßung", ICON_16_DIMORD, ICON_16_DIMORD)]^C^C_dimordinate
ID_Dimradius [_Button("Radiusbemaßung", ICON_16_DIMRAD, ICON_16_DIMRAD)]^C^C_dimradius
ID_Dimdiamet [_Button("Durchmesserbemaßung", ICON_16_DIMDIA, ICON_16_DIMDIA)]^C^C_dimdiameter
ID_Dimangula [_Button("Winkelbemaßung", ICON_16_DIMANG, ICON_16_DIMANG)]^C^C_dimangular
ID_Dimbaseli [_Button("Basislinienbemaßung", ICON_16_DIMBAS, ICON_16_DIMBAS)]^C^C_dimbaseline
ID_Dimcontin [_Button("Weiterführende Bemaßung", ICON_16_DIMCON, ICON_16_DIMCON)]^C^C_dimcontinue
ID_Leader [_Button("Schnellführung", ICON_16_QLEADER, ICON_16_QLEADER)]^C^C_qleader
ID_Tolerance [_Button("Toleranz", ICON_16_TOLERA, ICON_16_TOLERA)]^C^C_tolerance
ID_Dimcenter [_Button("Zentrumsmarke", ICON_16_DIMCEN, ICON_16_DIMCEN)]^C^C_dimcenter
ID_Dimedit [_Button("Bemaßung bearbeiten", ICON_16_DIMNEW, ICON_16_DIMNEW)]^C^C_dimedit
ID_Dimtedit [_Button("Maßtext bearbeiten", ICON_16_DIMRED, ICON_16_DIMRED)]^C^C_dimtedit
ID_DimstyleA [_Button("Bemaßung aktualisieren", ICON_16_DIMUPD, ICON_16_DIMUPD)]^C^C_-dimstyle _apply
ID_DimStyle [_Control(_dimstyle)]
ID_Ddim [_Button("Bemaßungsstil", ICON_16_DIMSTY, ICON_16_DIMSTY)]'_dimstyle
**TB_DRAW
ID_TbDraw [_Toolbar("Zeichnen", _Left, _Show, 0, 0, 1)]
ID_Line [_Button("Linie", ICON_16_LINE, ICON_16_LINE)]^C^C_line
ID_Xline [_Button("Konstruktionslinie", ICON_16_XLINE, ICON_16_XLINE)]^C^C_xline
ID_Dline [_Button("Doppellinie", ICON_16_DLINE, ICON_16_DLINE)]^C^C_dline
ID_Pline [_Button("Polylinie", ICON_16_PLINE, ICON_16_PLINE)]^C^C_pline
ID_Polygon [_Button("Polygon", ICON_16_POLYGO, ICON_16_POLYGO)]^C^C_polygon
ID_Rectang [_Button("Rechteck", ICON_16_RECTAN, ICON_16_RECTAN)]^C^C_rectang
ID_Arc [_Button("Bogen", ICON_16_ARC3PT, ICON_16_ARC3PT)]^C^C_arc
ID_Circle [_Button("Kreis", ICON_16_CIRRAD, ICON_16_CIRRAD)]^C^C_circle
ID_Revcloud [_Button("Revisionswolke", ICON_16_REVCLOUD, ICON_16_REVCLOUD)]^C^C_revcloud
ID_Spline [_Button("Spline", ICON_16_SPLINE, ICON_16_SPLINE)]^C^C_spline
ID_Ellipse [_Button("Ellipse", ICON_16_ELLAE, ICON_16_ELLAE)]^C^C_ellipse
ID_TbInsert [_Flyout("Flyout Einfügen", ICON_16_DINSER, ICON_16_DINSER, _OtherIcon, ACLT.TB_INSERT)]
ID_Bmake [_Button("Block erstellen", ICON_16_BLOCK, ICON_16_BLOCK)]^C^C_block
ID_PointMult [_Button("Punkt", ICON_16_POINT, ICON_16_POINT)]*^C^C_point
ID_Bhatch [_Button("Schraffur", ICON_16_BHATCH, ICON_16_BHATCH)]^C^C_bhatch
ID_Region [_Button("Region", ICON_16_REGION, ICON_16_REGION)]^C^C_region
ID_Mtext [_Button("Absatztext", ICON_16_MTEXT, ICON_16_MTEXT)]^C^C_mtext
**TB_GROUP
ID_TbGroup [_Toolbar("Gruppieren", _Floating, _Hide, 100, 130, 1)]
ID_QkGroup [_Button("Gruppieren", ICON_16_QKGROUP, ICON_16_QKGROUP)]^C^C_-pkfstgroup; * ;
ID_QkUnGroup [_Button("Gruppierung aufheben", ICON_16_QKUGROUP, ICON_16_QKUGROUP)]^C^C__qkungroup
ID_GroupDlg [_Button("Gruppenmanager", ICON_16_GROUP, ICON_16_GROUP)]^C^C_pkfstgroup
ID_Pickstyle [_Button("Gruppenauswahl ein/aus", ICON_16_PICKSTYLE, ICON_16_PICKSTYLE)]+
'_setvar;pickstyle;$M=$(if,$(eq,$(getvar,pickstyle),0),1,$(if,$(eq,$(getvar,pickstyle),1),0,+
$(if,$(eq,$(getvar,pickstyle),2),3,2)))
**TB_INQUIRY
ID_TbInquiry [_Toolbar("Abfrage", _Floating, _Hide, 100, 170, 1)]
ID_Dist [_Button("Abstand", ICON_16_DIST, ICON_16_DIST)]'_dist
ID_Area [_Button("Fläche", ICON_16_AREA, ICON_16_AREA)]^C^C_area
ID_Massprop [_Button("Region/Masseneigenschaften", ICON_16_MASSPR, ICON_16_MASSPR)]^C^C_massprop
ID_List [_Button("Liste", ICON_16_LIST, ICON_16_LIST)]^C^C_list
ID_Id [_Button("ID Punkt", ICON_16_ID, ICON_16_ID)]'_id
**TB_INSERT
ID_TbInsert [_Toolbar("Einfügen", _Floating, _Hide, 100, 190, 1)]
ID_Ddinsert [_Button("Block einfügen", ICON_16_DINSER, ICON_16_DINSER)]^C^C_insert
ID_Xref [_Button("Externe Referenz", ICON_16_XREATT, ICON_16_XREATT)]^C^C_xref
ID_Import [_Button("Importieren", ICON_16_IMPORT, ICON_16_IMPORT)]^C^C_import
ID_Insertobj [_Button("OLE-Objekt", ICON_16_INSOLE, ICON_16_INSOLE)]^C^C_insertobj
**TB_LAYOUTS
ID_TbLayouts [_Toolbar("Layouts", _Floating, _Hide, 100, 350, 1)]
ID_LayNew [_Button("Neues Layout", ICON_16_LAYNEW, ICON_16_LAYNEW)]^C^C_-layout _n
ID_LayTemp [_Button("Layout von Vorlage", ICON_16_LAYTEM, ICON_16_LAYTEM)]^C^C_-layout _t
ID_PlotSetup [_Button("Seite einrichten", ICON_16_PLTSET, ICON_16_PLTSET)]^C^C_pagesetup
ID_VpDialog [_Button("Dialogfeld Ansichtsfenster anzeigen", ICON_16_VPDLG, ICON_16_VPDLG)]^C^C_vports
**TB_MODIFY
ID_TbModify [_Toolbar("Ändern", _Left, _Show, 1, 0, 1)]
ID_Erase [_Button("Löschen", ICON_16_ERASE, ICON_16_ERASE)]^C^C_erase
ID_Copy [_Button("Objekt kopieren", ICON_16_COPYOB, ICON_16_COPYOB)]$M=$(if,$(eq,+
$(substr,$(getvar,cmdnames),1,4),grip),_copy,^C^C_copy)
ID_Mirror [_Button("Spiegeln", ICON_16_MIRROR, ICON_16_MIRROR)]$M=$(if,$(eq,+
$(substr,$(getvar,cmdnames),1,4),grip),_mirror,^C^C_mirror)
ID_Offset [_Button("Versetzen", ICON_16_OFFSET, ICON_16_OFFSET)]^C^C_offset
ID_Array [_Button("Reihe", ICON_16_ARRREC, ICON_16_ARRREC)]^C^C_array
ID_Move [_Button("Schieben", ICON_16_MOVE, ICON_16_MOVE)]$M=$(if,$(eq,+
$(substr,$(getvar,cmdnames),1,4),grip),_move,^C^C_move)
ID_Rotate [_Button("Drehen", ICON_16_ROTATE, ICON_16_ROTATE)]$M=$(if,$(eq,+
$(substr,$(getvar,cmdnames),1,4),grip),_rotate,^C^C_rotate)
ID_Scale [_Button("Varia", ICON_16_SCALE, ICON_16_SCALE)]$M=$(if,$(eq,+
$(substr,$(getvar,cmdnames),1,4),grip),_scale,^C^C_scale)
ID_Stretch [_Button("Strecken", ICON_16_STRETC, ICON_16_STRETC)]$M=$(if,$(eq,+
ID_Lengthen [_Button("Länge", ICON_16_LENGTH, ICON_16_LENGTH)]^C^C_lengthen
ID_Trim [_Button("Stutzen", ICON_16_TRIM, ICON_16_TRIM)]^C^C_trim
ID_Extend [_Button("Dehnen", ICON_16_EXTEND, ICON_16_EXTEND)]^C^C_extend
ID_BreakSele [_Button("An Punkt brechen", ICON_16_BREAKATPT, ICON_16_BREAKATPT)]^C^C_break \f \@
ID_Break [_Button("Bruch", ICON_16_BRE2PT, ICON_16_BRE2PT)]^C^C_break
ID_Chamfer [_Button("Fasen", ICON_16_CHAMFE, ICON_16_CHAMFE)]^C^C_chamfer
ID_Fillet [_Button("Abrunden", ICON_16_FILLET, ICON_16_FILLET)]^C^C_fillet
ID_Explode [_Button("Ursprung", ICON_16_EXPLOD, ICON_16_EXPLOD)]^C^C_explode
**TB_MODIFY_II
ID_TbModifII [_Toolbar("Ändern II", _Floating, _Hide, 100, 270, 1)]
ID_Draworder [_Button("Zeichnungsreihenfolge",ICON_16_DRWORD,ICON_16_DRWORD)]^C^C_draworder
ID_Hatchedit [_Button("Schraffur bearbeiten", ICON_16_HATEDI, ICON_16_HATEDI)]^C^C_hatchedit
ID_Pedit [_Button("Polylinien bearbeiten", ICON_16_PEDIT, ICON_16_PEDIT)]^C^C_pedit
ID_Splinedit [_Button("Spline bearbeiten", ICON_16_SPLEDI, ICON_16_SPLEDI)]^C^C_splinedit
ID_AtteditSin [_Button("Attribute bearbeiten", ICON_16_ATTEDI, ICON_16_ATTEDI)]^C^C_attedit
**TB_OBJECT_PROPERTIES
ID_TbObjectP [_Toolbar("Eigenschaften", _Top, _Show, 0, 1, 1)]
ID_Ai_molc [_Button("Objektlayer zum aktuellen machen", ICON_16_MOLC, ICON_16_MOLC)]^C^C_ai_molc
ID_Layer [_Button("Layer", ICON_16_LAYERS, ICON_16_LAYERS)]'_layer
ID_CtrlLayer [_Control(_Layer)]
ID_CtrlColor [_Control(_Color)]
ID_CtrlLinet [_Control(_Linetype)]
ID_CtrlLineW [_Control(_Lineweight)]
ID_CtrlPStyl [_Control(_PlotStyle)]
**TB_OBJECT_SNAP
ID_TbOsnap [_Toolbar("Objektfang", _Floating, _Hide, 100, 210, 1)]
ID_Tracking [_Button("Spur", ICON_16_TRACK, ICON_16_TRACK)]_tracking
ID_From [_Button("Fang von Punkt", ICON_16_OSNFRO, ICON_16_OSNFRO)]_from
ID_OsnapEndp [_Button("Fang Endpunkt", ICON_16_OSNEND, ICON_16_OSNEND)]_endp
ID_OsnapMidp [_Button("Fang Mittelpunkt", ICON_16_OSNMID, ICON_16_OSNMID)]_mid
ID_OsnapInte [_Button("Fang Schnittpunkt", ICON_16_OSNINT, ICON_16_OSNINT)]_int
ID_OsnapAppa [_Button("Fang Angenomm. Schnittpunkt", ICON_16_OSNAPP, ICON_16_OSNAPP)]_appint
ID_OsnapCent [_Button("Fang Zentrum", ICON_16_OSNCEN, ICON_16_OSNCEN)]_cen
ID_OsnapQuad [_Button("Fang Quadrant", ICON_16_OSNQUA, ICON_16_OSNQUA)]_qua
ID_OsnapTang [_Button("Fang Tangente", ICON_16_OSNTAN, ICON_16_OSNTAN)]_tan
ID_OsnapPerp [_Button("Fang Lot", ICON_16_OSNPER, ICON_16_OSNPER)]_per
ID_OsnapInse [_Button("Fang Basispunkt", ICON_16_OSNINS, ICON_16_OSNINS)]_ins
ID_OsnapNode [_Button("Fang Punkt", ICON_16_OSNNOD, ICON_16_OSNNOD)]_nod
ID_OsnapNear [_Button("Fang Nächster Punkt", ICON_16_OSNNEA, ICON_16_OSNNEA)]_nea
ID_OsnapNone [_Button("Kein Fang", ICON_16_OSNNON, ICON_16_OSNNON)]_non
ID_Osnap [_Button("Objektfang-Einstellungen", ICON_16_OSNAP, ICON_16_OSNAP)]'_osnap
**TB_REFERENCE
ID_TbReferen [_Toolbar("Referenz", _Floating, _Hide, 100, 370, 1)]
ID_Xattach [_Button("Externe Referenz hinzufügen", ICON_16_XATTAC, ICON_16_XATTAC)]^C^C_xattach
ID_Xbind [_Button("Externe Referenz binden",ICON_16_XBIND,ICON_16_XBIND)]^C^C_xbind
ID_Xclipfram [_Button("Zuschneide-Rahmen Externe Referenz",ICON_16_XCLIPFRAME,ICON_16_XCLIPFRAME)]$M=$(if,$(eq,$(getvar,xclipframe),1),^C^C_xclipframe 0,^C^C_xclipframe 1)
ID_Image [_Button("Bild", ICON_16_IMAGE, ICON_16_IMAGE)]^C^C_image
ID_Imagefram [_Button("Bildrahmen",ICON_16_IMGFRAME, ICON_16_IMGFRAME)]^C^C_imageframe
**TB_STANDARD
ID_TbStandar [_Toolbar("Standard-Funktionsleiste", _Top, _Show, 0, 0, 1)]
ID_New [_Button("Neu", ICON_16_NEW, ICON_16_NEW)]^C^C_new
ID_Open [_Button("Öffnen", ICON_16_OPEN, ICON_16_OPEN)]^C^C_open
ID_Save [_Button("Speichern", ICON_16_SAVE, ICON_16_SAVE)]^C^C_qsave
ID_Print [_Button("Plotten", ICON_16_PRINT, ICON_16_PRINT)]^C^C_plot
ID_Preview [_Button("Plot-Voransicht", ICON_16_PREVIEW, ICON_16_PREVIEW)]^C^C_preview
ID_TextFind [_Button("Suchen und Ersetzen", ICON_16_TEXTFIND, ICON_16_TEXTFIND)]^C^C_find
ID_Cutclip [_Button("Ausschneiden", ICON_16_CUT, ICON_16_CUT)]^C^C_cutclip
ID_Copyclip [_Button("Kopieren", ICON_16_COPY, ICON_16_COPY)]^C^C_copyclip
ID_Pasteclip [_Button("Einfügen", ICON_16_PASTE, ICON_16_PASTE)]^C^C_pasteclip
ID_Matchprop [_Button("Eig. anpassen", ICON_16_MATCH, ICON_16_MATCH)]'_matchprop
ID_CtrlUndo [_Control(_Undo)]
ID_CtrlRedo [_Control(_Redo)]
ID_Today [_Button("Aktuell", ICON_16_TODAY, ICON_16_TODAY)]^C^C_Today
ID_PointA [_Button("Autodesk Point A", ICON_16_WHISTLER, ICON_16_WHISTLER)]^C^C_browser http://pointa.autodesk.com
ID_MeetNow [_Button("Besprechung", ICON_16_MEETNOW, ICON_16_MEETNOW)]^C^C_MeetNow
ID_Publish [_Button("Im Web publizieren", ICON_16_PUBWEB, ICON_16_PUBWEB)]^C^C_PublishToWeb
ID_Etransmit [_Button("eTransmit", ICON_16_ETRANSMIT, ICON_16_ETRANSMIT)]^C^C_etransmit
ID_Hyperlink [_Button("Hyperlink einfügen", ICON_16_URL, ICON_16_URL)]^C^C_hyperlink
ID_TbOsnap [_Flyout("Flyout Objektfang", ICON_16_TRACK, ICON_16_TRACK, _OtherIcon, ACLT.TB_OBJECT_SNAP)]
ID_TbUcs [_Flyout("Flyout BKS", ICON_16_UCS, ICON_16_UCS, _OtherIcon, ACLT.TB_UCS)]
ID_Draworder [_Button("Zeichenreihenfolge", ICON_16_DRWORD, ICON_16_DRWORD)]^C^C_draworder
ID_TbViewpoi [_Flyout("Flyout Ansicht", ICON_16_DDVIEW, ICON_16_DDVIEW, _OtherIcon, ACLT.TB_VIEWPOINT)]
ID_Pan [_Button("Echtzeit-Pan", ICON_16_RTPAN, ICON_16_RTPAN)]'_pan
ID_ZoomRealt [_Button("Echtzeit-Zoom", ICON_16_RTZOOM, ICON_16_RTZOOM)]'_zoom ;
ID_TbZoom [_Flyout("Flyout Zoom", ICON_16_ZOOWIN, ICON_16_ZOOWIN, _OtherIcon, ACLT.TB_ZOOM)]
ID_ZoomPrevi [_Button("Zoom Vorher", ICON_16_ZOOPRE, ICON_16_ZOOPRE)]'_zoom _p
ID_Content [_Button("AutoCAD DesignCenter", ICON_16_OPTCONTENTX, ICON_16_OPTCONTENTX)]$M=$(if,$(and,$(getvar,adcstate),1),'_adcclose,'_adcenter)
ID_Modify [_Button("Eigenschaften", ICON_16_MODIFY, ICON_16_MODIFY)]$M=$(if,$(and,$(getvar,opmstate),1),^C^C_propertiesclose,^C^C_properties)
ID_Help [_Button("Hilfe", ICON_16_HELP, ICON_16_HELP)]'_help
ID_ASSIST [_Button("Aktive Hilfe", ICON_16_ASSIST, ICON_16_ASSIST)]'_ASSIST
**TB_TEXT
ID_TbText [_Toolbar("Text", _Floating, _Hide, 100, 320, 1)]
ID_Dtext [_Button("Einzeiliger Text", ICON_16_SINGLE_DTEXT, ICON_16_SINGLE_DTEXT]^C^C_dtext
ID_Ddedit [_Button("Text bearbeiten", ICON_16_TEXEDI, ICON_16_TEXEDI)]^C^C_ddedit
ID_Style [_Button("Textstil",ICON_16_TXTSTYLE, ICON_16_TXTSTYLE]'_style
ID_Scaletext [_Button("Text skalieren", ICON_16_SCALETXT, ICON_16_SCALETXT]^C^C_scaletext
ID_Justifyte [_Button("Text ausrichten", ICON_16_JUSTIFYTXT, ICON_16_JUSTIFYTXT]^C^C_justifytext
ID_Spacetran [_Button("Entfernung zwischen Leerzeichen konvertieren",ICON_16_SPACETRANS, ICON_16_SPACETRANS]'_spacetrans
**TB_UCS
ID_TbUcs [_Toolbar("BKS", _Floating, _Hide, 100, 310, 1)]
ID_Ucs [_Button("BKS", ICON_16_UCS, ICON_16_UCS)]^C^C_ucs
ID_Dducs [_Button("BKS-Dialogfeld anzeigen", ICON_16_DDUCS, ICON_16_DDUCS)]^C^C_+ucsman 0
ID_UcsPrevio [_Button("Vorheriges BKS", ICON_16_UCSPRE, ICON_16_UCSPRE)]^C^C_ucs _p
ID_UcsWorld [_Button("Welt", ICON_16_UCSW, ICON_16_UCSW)]^C^C_ucs _w
ID_UcsObject [_Button("Objekt", ICON_16_UCSOBJ, ICON_16_UCSOBJ)]^C^C_ucs _ob
ID_UcsFace [_Button("Fläche BKS", ICON_16_UCSFACE, ICON_16_UCSFACE)]^C^C_ucs _fa
ID_UcsView [_Button("Ansicht", ICON_16_UCSVIE, ICON_16_UCSVIE)]^C^C_ucs _v
ID_UcsOrigin [_Button("Ursprung", ICON_16_UCSORI, ICON_16_UCSORI)]^C^C_ucs _o
ID_UcsZAxVec [_Button("Z-Achse", ICON_16_UCSZAV, ICON_16_UCSZAV)]^C^C_ucs _zaxis
ID_Ucs3point [_Button("3 Punkte", ICON_16_UCS3PT, ICON_16_UCS3PT)]^C^C_ucs _3
ID_UcsXAxRot [_Button("X-Achse drehen", ICON_16_UCSXAR, ICON_16_UCSXAR)]^C^C_ucs _x
ID_UcsYAxRot [_Button("Y-Achse drehen", ICON_16_UCSYAR, ICON_16_UCSYAR)]^C^C_ucs _y
ID_UcsZAxRot [_Button("Z-Achse drehen", ICON_16_UCSZAR, ICON_16_UCSZAR)]^C^C_ucs _z
**TB_UCSII
ID_TbUcsName [_Toolbar("BKS II", _Floating, _Hide, 100, 300, 1)]
ID_UcsMove [_Button("BKS-Ursprung verschieben", ICON_16_UCSMOVE, ICON_16_UCSMOVE)]^C^C_ucs _move
ID_UcsCombo [_Control(_UCSManager)]
**TB_VIEWPOINT
ID_TbViewpoi [_Toolbar("Ansicht", _Floating, _Hide, 100, 330, 1)]
ID_Ddview [_Button("Benannte Ausschnitte", ICON_16_DDVIEW, ICON_16_DDVIEW)]^C^C_view
ID_VpointTop [_Button("Draufsicht", ICON_16_VIETOP, ICON_16_VIETOP)]^C^C_-view _top
ID_VpointBot [_Button("Untersicht", ICON_16_VIEBOT, ICON_16_VIEBOT)]^C^C_-view _bottom
ID_VpointLef [_Button("Seitenansicht links", ICON_16_VIELEF, ICON_16_VIELEF)]^C^C_-view _left
ID_VpointRig [_Button("Seitenansicht rechts", ICON_16_VIERIG, ICON_16_VIERIG)]^C^C_-view _right
ID_VpointFro [_Button("Vorderansicht", ICON_16_VIEFRO, ICON_16_VIEFRO)]^C^C_-view _front
ID_VpointBac [_Button("Rückansicht", ICON_16_VIEBAC, ICON_16_VIEBAC)]^C^C_-view _back
ID_VpointSW [_Button("Isometrieansicht Südwest", ICON_16_VIESWI, ICON_16_VIESWI)]^C^C_-view _swiso
ID_VpointSE [_Button("Isometrieansicht Südost", ICON_16_VIESEI, ICON_16_VIESEI)]^C^C_-view _seiso
ID_VpointNE [_Button("Isometrieansicht Nordost", ICON_16_VIENEI, ICON_16_VIENEI)]^C^C_-view _neiso
ID_VpointNW [_Button("Isometrieansicht Nordwest", ICON_16_VIENWI, ICON_16_VIENWI)]^C^C_-view _nwiso
**TB_VIEWPORTS
ID_TbVpCreat [_Toolbar("Ansichtsfenster", _Floating, _Hide, 100, 350, 1)]
ID_VpSingle [_Button("Einzelnes Ansichtsfenster", ICON_16_VPONE, ICON_16_VPONE)]$M=$(if,$(eq,$(getvar,tilemode),1),^C^C_-vports _si,^C^C_-vports)
ID_VPScale [_Control(_ViewportScale)]
**TB_WEB
ID_TbWeb [_Toolbar("Web", _Floating, _Hide, 100, 380, 1)]
ID_HlnkBack [_Button("Zurück", ICON_16_HLNK_BACK, ICON_16_HLNK_BACK)]'_hyperlinkBack
ID_HlnkFwd [_Button("Vorwärts", ICON_16_HLNK_FWD, ICON_16_HLNK_FWD)]'_hyperlinkFwd
ID_HlnkStop [_Button("Beenden", ICON_16_HLNK_STOP, ICON_16_HLNK_STOP)]'_hyperlinkStop
ID_Browser [_Button("Internet durchsuchen", ICON_16_WEB, ICON_16_WEB)]^C^C_browser ;
**TB_ZOOM
ID_TbZoom [_Toolbar("Zoom", _Floating, _Hide, 100, 350, 1)]
ID_ZoomWindo [_Button("Zoom Fenster", ICON_16_ZOOWIN, ICON_16_ZOOWIN)]'_zoom _w
ID_ZoomDynam [_Button("Dynamischer Zoom", ICON_16_ZOODYN, ICON_16_ZOODYN)]'_zoom _d
ID_ZoomScale [_Button("Zoomfaktor", ICON_16_ZOOSCA, ICON_16_ZOOSCA)]'_zoom _s
ID_ZoomCente [_Button("Zoom Mittelpunkt", ICON_16_ZOOCEN, ICON_16_ZOOCEN)]'_zoom _c
ID_ZoomIn [_Button("Vergrößern", ICON_16_ZOOIN, ICON_16_ZOOIN)]'_zoom 2x
ID_ZoomOut [_Button("Verkleinern", ICON_16_ZOOOUT, ICON_16_ZOOOUT)]'_zoom .5x
ID_ZoomAll [_Button("Alles zoomen", ICON_16_ZOOALL, ICON_16_ZOOALL)]'_zoom _all
ID_ZoomExten [_Button("Zoom Grenzen", ICON_16_ZOOEXT, ICON_16_ZOOEXT)]'_zoom _e
// Begin AutoCAD LT Tablet Menus
// This is the TABLET1 menu. You may put your own
// macros and menu items here in these spaces.
// All of the "blank" line items actually contain a
// backslash so that a RETURN is issued when you pick any
// of them from the tablet. Remove them if you want nothing
// to happen when they are selected, or place your own
// macros in their place.
***TABLET1
**TABLET1STD
[A-1]\
[A-2]\
[A-3]\
[A-4]\
[A-5]\
[A-6]\
[A-7]\
[A-8]\
[A-9]\
[A-10]\
[A-11]\
[A-12]\
[A-13]\
[A-14]\
[A-15]\
[A-16]\
[A-17]\
[A-18]\
[A-19]\
[A-20]\
[A-21]\
[A-22]\
[A-23]\
[A-24]\
[A-25]\
[B-1]\
[B-2]\
[B-3]\
[B-4]\
[B-5]\
[B-6]\
[B-7]\
[B-8]\
[B-9]\
[B-10]\
[B-11]\
[B-12]\
[B-13]\
[B-14]\
[B-15]\
[B-16]\
[B-17]\
[B-18]\
[B-19]\
[B-20]\
[B-21]\
[B-22]\
[B-23]\
[B-24]\
[B-25]\
[C-1]\
[C-2]\
[C-3]\
[C-4]\
[C-5]\
[C-6]\
[C-7]\
[C-8]\
[C-9]\
[C-10]\
[C-11]\
[C-12]\
[C-13]\
[C-14]\
[C-15]\
[C-16]\
[C-17]\
[C-18]\
[C-19]\
[C-20]\
[C-21]\
[C-22]\
[C-23]\
[C-24]\
[C-25]\
[D-1]\
[D-2]\
[D-3]\
[D-4]\
[D-5]\
[D-6]\
[D-7]\
[D-8]\
[D-9]\
[D-10]\
[D-11]\
[D-12]\
[D-13]\
[D-14]\
[D-15]\
[D-16]\
[D-17]\
[D-18]\
[D-19]\
[D-20]\
[D-21]\
[D-22]\
[D-23]\
[D-24]\
[D-25]\
[E-1]\
[E-2]\
[E-3]\
[E-4]\
[E-5]\
[E-6]\
[E-7]\
[E-8]\
[E-9]\
[E-10]\
[E-11]\
[E-12]\
[E-13]\
[E-14]\
[E-15]\
[E-16]\
[E-17]\
[E-18]\
[E-19]\
[E-20]\
[E-21]\
[E-22]\
[E-23]\
[E-24]\
[E-25]\
[F-1]\
[F-2]\
[F-3]\
[F-4]\
[F-5]\
[F-6]\
[F-7]\
[F-8]\
[F-9]\
[F-10]\
[F-11]\
[F-12]\
[F-13]\
[F-14]\
[F-15]\
[F-16]\
[F-17]\
[F-18]\
[F-19]\
[F-20]\
[F-21]\
[F-22]\
[F-23]\
[F-24]\
[F-25]\
[G-1]\
[G-2]\
[G-3]\
[G-4]\
[G-5]\
[G-6]\
[G-7]\
[G-8]\
[G-9]\
[G-10]\
[G-11]\
[G-12]\
[G-13]\
[G-14]\
[G-15]\
[G-16]\
[G-17]\
[G-18]\
[G-19]\
[G-20]\
[G-21]\
[G-22]\
[G-23]\
[G-24]\
[G-25]\
[H-1]\
[H-2]\
[H-3]\
[H-4]\
[H-5]\
[H-6]\
[H-7]\
[H-8]\
[H-9]\
[H-10]\
[H-11]\
[H-12]\
[H-13]\
[H-14]\
[H-15]\
[H-16]\
[H-17]\
[H-18]\
[H-19]\
[H-20]\
[H-21]\
[H-22]\
[H-23]\
[H-24]\
[H-25]\
[I-1]\
[I-2]\
[I-3]\
[I-4]\
[I-5]\
[I-6]\
[I-7]\
[I-8]\
[I-9]\
[I-10]\
[I-11]\
[I-12]\
[I-13]\
[I-14]\
[I-15]\
[I-16]\
[I-17]\
[I-18]\
[I-19]\
[I-20]\
[I-21]\
[I-22]\
[I-23]\
[I-24]\
[I-25]\
**ENDTAB1
// This is the alternate TABLET1 menu.
**TABLET1ALT
[A-1]\
[A-2]\
[A-3]\
[A-4]\
[A-5]\
[A-6]\
[A-7]\
[A-8]\
[A-9]\
[A-10]\
[A-11]\
[A-12]\
[A-13]\
[A-14]\
[A-15]\
[A-16]\
[A-17]\
[A-18]\
[A-19]\
[A-20]\
[A-21]\
[A-22]\
[A-23]\
[A-24]\
[A-25]\
[B-1]\
[B-2]\
[B-3]\
[B-4]\
[B-5]\
[B-6]\
[B-7]\
[B-8]\
[B-9]\
[B-10]\
[B-11]\
[B-12]\
[B-13]\
[B-14]\
[B-15]\
[B-16]\
[B-17]\
[B-18]\
[B-19]\
[B-20]\
[B-21]\
[B-22]\
[B-23]\
[B-24]\
[B-25]\
[C-1]\
[C-2]\
[C-3]\
[C-4]\
[C-5]\
[C-6]\
[C-7]\
[C-8]\
[C-9]\
[C-10]\
[C-11]\
[C-12]\
[C-13]\
[C-14]\
[C-15]\
[C-16]\
[C-17]\
[C-18]\
[C-19]\
[C-20]\
[C-21]\
[C-22]\
[C-23]\
[C-24]\
[C-25]\
[D-1]\
[D-2]\
[D-3]\
[D-4]\
[D-5]\
[D-6]\
[D-7]\
[D-8]\
[D-9]\
[D-10]\
[D-11]\
[D-12]\
[D-13]\
[D-14]\
[D-15]\
[D-16]\
[D-17]\
[D-18]\
[D-19]\
[D-20]\
[D-21]\
[D-22]\
[D-23]\
[D-24]\
[D-25]\
[E-1]\
[E-2]\
[E-3]\
[E-4]\
[E-5]\
[E-6]\
[E-7]\
[E-8]\
[E-9]\
[E-10]\
[E-11]\
[E-12]\
[E-13]\
[E-14]\
[E-15]\
[E-16]\
[E-17]\
[E-18]\
[E-19]\
[E-20]\
[E-21]\
[E-22]\
[E-23]\
[E-24]\
[E-25]\
[F-1]\
[F-2]\
[F-3]\
[F-4]\
[F-5]\
[F-6]\
[F-7]\
[F-8]\
[F-9]\
[F-10]\
[F-11]\
[F-12]\
[F-13]\
[F-14]\
[F-15]\
[F-16]\
[F-17]\
[F-18]\
[F-19]\
[F-20]\
[F-21]\
[F-22]\
[F-23]\
[F-24]\
[F-25]\
[G-1]\
[G-2]\
[G-3]\
[G-4]\
[G-5]\
[G-6]\
[G-7]\
[G-8]\
[G-9]\
[G-10]\
[G-11]\
[G-12]\
[G-13]\
[G-14]\
[G-15]\
[G-16]\
[G-17]\
[G-18]\
[G-19]\
[G-20]\
[G-21]\
[G-22]\
[G-23]\
[G-24]\
[G-25]\
[H-1]\
[H-2]\
[H-3]\
[H-4]\
[H-5]\
[H-6]\
[H-7]\
[H-8]\
[H-9]\
[H-10]\
[H-11]\
[H-12]\
[H-13]\
[H-14]\
[H-15]\
[H-16]\
[H-17]\
[H-18]\
[H-19]\
[H-20]\
[H-21]\
[H-22]\
[H-23]\
[H-24]\
[H-25]\
[I-1]\
[I-2]\
[I-3]\
[I-4]\
[I-5]\
[I-6]\
[I-7]\
[I-8]\
[I-9]\
[I-10]\
[I-11]\
[I-12]\
[I-13]\
[I-14]\
[I-15]\
[I-16]\
[I-17]\
[I-18]\
[I-19]\
[I-20]\
[I-21]\
[I-22]\
[I-23]\
[I-24]\
[I-25]\
**ENDTAB1A
// This is the standard TABLET2 menu.
// Where allowed, commands are invoked transparently.
***TABLET2
**TABLET2STD
// Row J UCS/Inquiry/Layer
^C^C_ucs _w
^C^C_dducs
'_layer
'_layer
'_layer
[DRAW/ZOOM]\
^C^C_dline
^C^C_dline
^C^C_line
^C^C_line
^C^C_regen
// Row K UCS/Inquiry/Layer
^C^C_ucs _p
^C^C_dducsp
'_-layer _on
'_-layer _t
^C^C_vplayer $M=$(if,$(getvar,tilemode),,_t )^Z
[DRAW/ZOOM]\
^C^C_spline
^C^C_spline
^C^C_pline
^C^C_pline
^C^C_regen
// Row L UCS/Inquiry/Layer
^C^C_list
^C^C_list
'_-layer _off
'_-layer _f
^C^C_vplayer $M=$(if,$(getvar,tilemode),,_f )^Z
[DRAW/ZOOM]\
^C^C_ray
^C^C_ray
^C^C_xline
^C^C_xline
'_zoom ;
// Row M UCS/Inquiry/Layer
'_id
'_dist
'_-layer _lo
'_-layer _u
^C^C_vplayer
[DRAW/ZOOM]\
^C^C_arc
^C^C_arc
^C^C_circle
^C^C_circle
'_zoom ;
// Row N UCS/Inquiry/Layer
^C^C_area
^C^C_massprop
[DRAW/ZOOM]\
^C^C_polygon
^C^C_polygon
^C^C_ellipse
^C^C_ellipse
'_pan
// Row O UCS/Inquiry/Layer
[DRAW/ZOOM]\
^C^C_donut
^C^C_donut
^C^C_point
^C^C_point
'_pan
// Row P UCS/Inquiry/Layer
^C^C_hide
^C^C_shadedge;0;_shade
^C^C_mview $M=$(if,$(getvar,tilemode),,_off )^Z
^C^C_mview $M=$(if,$(getvar,tilemode),,_on )^Z
^C^C_mview
[DRAW/ZOOM]\
^C^C_bhatch
^C^C_bhatch
'_redraw
// Row Q UCS/Inquiry/Layer
^C^C_vpoint;;
^C^C_plan;;
^C^C_mview $M=$(if,$(getvar,tilemode),,_4 )^Z
^C^C_mview $M=$(if,$(getvar,tilemode),,_3 )^Z
^C^C_mview $M=$(if,$(getvar,tilemode),,_2 )^Z
[DRAW/ZOOM]\
'_zoom _c
^C^C_zoom _a
'_zoom 2x
^C^C_revcloud
'_redraw
// Row R UCS/Inquiry/Layer
^C^C_dview $M=$(if,$(getvar,tilemode),;_off _x )^Z
^C^C_dview
^C^C_vports $M=$(if,$(getvar,tilemode),_s )^Z
^C^C_mview $M=$(if,$(getvar,tilemode),,_r )^Z
^C^C_vports
[DRAW/ZOOM]\
'_zoom _p
^C^C_zoom _e
'_zoom .5x
^C^C_region
'_redraw
**ENDTAB2
// TABLET3 menu.
// This tablet menu is 9 colums wide by 13 rows high.
// The equivalent area on the tablet drawing shows an empty column followed by three colums
// that are slightly narrower than the normal columns.
// The 9 tablet menu columns are used as follows:
// - 3 tablet menu columns for the blank column in the tablet drawing
// - 2 tablet menu columns for each of the 3 narrow tablet drawing columns
***TABLET3
**TABLET3STD
// Row 1
<<135
<<135
<<90
<<90
<<45
<<45
// Row 2
<<180
<<180
<<0
<<0
// Row 3
<<225
<<225
<<270
<<270
<<315
<<315
// Row 4
^H
^H
^H
^H
^H
^H
// Row 5
7/8\
7/8\
/16\
/16\
/32\
/32\
// Row 6
1/2\
1/2\
5/8\
5/8\
3/4\
3/4\
// Row 7
1/8\
1/8\
1/4\
1/4\
3/8\
3/8\
// Row 8
X\
X\
// Row 9
// Row 10
7\
7\
8\
8\
9\
9\
// Row 11
4\
4\
5\
5\
6\
6\
// Row 12
1\
1\
2\
2\
3\
3\
// Row 13
0\
0\
**ENDTAB3
// This is the alternate TABLET3 menu.
// It provides Metric unit input.
**TABLET3ALT
<<135
<<135
<<90
<<90
<<45
<<45
<<180
<<180
<<0
<<0
<<225
<<225
<<270
<<270
<<315
<<315
^H
^H
^H
^H
^H
^H
m\
m\
cm\
cm\
mm\
mm\
%%p\
%%p\
%%d\
%%d\
%%c\
%%c\
X\
X\
7\
7\
8\
8\
9\
9\
4\
4\
5\
5\
6\
6\
1\
1\
2\
2\
3\
3\
0\
0\
00\
00\
000\
000\
**ENDTAB3ALT
// This is the standard TABLET4 menu.
// Menu item S22 contains a call to swap the tablet 3 menu.
// These items cause tablet menus to be swapped which contain
// various "expert" menu selections. A variable is used to
// hold bit-coded values which are on when the menu is swapped,
// i.e., when the alternate menu has been swapped in. Bit 1
// is on when menu area 1 is swapped, bit 2 when menu area 2
// is swapped, and so on with bits 4 and 8. Prompts describing
// the changes enacted via the menu provide feedback to the user.
// The prompts are tied to the setting of the EXPERT system
// variable. If the value of the EXPERT system variable is 0,
// then a prompt such as this will be issued;
// Menu area 3 has been swapped. Optional metric
// functionality is now active." If the value of the EXPERT
// system variable is 1-4, the prompt will be shortened to;
// Menu area 3 has been swapped.", and if the value of
// the EXPERT system variable is greater than 4, all prompts
// will be suppressed.
***TABLET4
**TABLET4STD
// Row S
[Tablet 3]$M=$(if,$(or,$(eq,$(getvar,CMDNAMES),TEXT),+
$(eq,$(getvar,CMDNAMES),DTEXT),$(eq,$(getvar,CMDNAMES),ATTDEF),+
$(eq,$(getvar,CMDNAMES),MTEXT)),^C^C,^Z)^P'_ai_tab3 ^P
// Row T
^C^C_dtext _a
^C^C_dtext _m
^C^C_dtext _f
'_spell
^C^C_mtext
[BLOCK/XREF/SETTINGS]\
'_?
'_?
^C^C^C
^C^C^C
[SNAP/TOGGLE/EDIT]\
_none
_center
_endpoint
_ins
_int
_midpoint
_nearest
_node
_perpend
_quadrant
_tangent
[UTILITY]\
^C^C_qsave
^C^C_saveas
// Row U
^C^C_dtext
^C^C_dtext _c
^C^C_dtext _r
'_ddstyle
^C^C_ddedit
_u
_u
^C^C_mredo 1
^C^C_mredo 1
[SNAP/TOGGLE/EDIT]\
_tk
_from
_fence
_cp
_wp
_window
_last
_previous
_crossing
_remove
_add
[UTILITY]\
^C^C_new
^C^C_open
// Row V
^C^C_tolerance
^C^C_-dimstyle _r
^C^C_-dimstyle _s
^C^C_ddim
^C^C_find
$M=$(if,$(getvar,cmdactive),^C^C,)_erase
^C^C_matchprop
[SNAP/TOGGLE/EDIT]\
^C^C_pkfstgroup
^C^C_qselect
^C^C_pspace
^C^C^P_ai_fms ^P
'_orthomode $M=$(-,1,$(getvar,orthomode))
^D
'_qtextmode $M=$(-,1,$(getvar,qtextmode))
^E
^G
^B
^C^C_ddvpoint
[UTILITY]\
^C^C_plot
^C^C_pagesetup
// Row W
^C^C_dimcenter
^C^C_dimedit _o
^C^C_dimtedit \_a
^C^C_dimtedit
^C^C_dimtedit \_h
^C^C_ddatte
^C^C_attdef
^C^C_bmake
^C^C_ddinsert
[SNAP/TOGGLE/EDIT]\
$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),,^C^C)_scale
$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),,^C^C)_rotate
^C^C_draworder
$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),,^C^C)_move
$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),,^C^C)_stretch
$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),,^C^C)_copy
[UTILITY]\
^C^C_preview
^C^C_options
//Row X
^C^C_qleader
^C^C_dimbaseline
^C^C_dimcontinue
^C^C_dimlinear
^C^C_dimlinear
^C^C_-xref _d
^C^C_-xref _o
^C^C_-xref _a
^C^C_xref
[SNAP/TOGGLE/EDIT]\
$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),,^C^C)_mirror
$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),,^C^C)_offset
^C^C_fillet _r 0;;
^C^C_fillet
^C^C_chamfer
^C^C_extend
^C^C_trim
^C^C_union
^C^C_subtract
^C^C_intersect
[UTILITY]\
^C^C_import
^C^C_export
// Row Y
^C^C_dimradius
^C^C_dimdiameter
^C^C_dimangular
^C^C_dimordinate
^C^C_dimaligned
'_ddunits
'_linetype
'_linetype
'_dsettings
[SNAP/TOGGLE/EDIT]\
^C^C_hatchedit
^C^C_splinedit
^C^C_pedit
^C^C_array
^C^C_array
^C^C_select;_single;\_break;@;@
^C^C_select;_single;\_break;@;_f
^C^C_measure
^C^C_divide
^C^C_lengthen
^C^C_explode
[UTILITY]\
^C^C_stylesmanager
^C^C_quit
**ENDTAB4
// Keyboard Accelerators
// If a keyboard accelerator is preceded by an ID string that references a menu item
// in a pull-down menu, then the keyboard accelerator will run the command referenced
// by that menu item. The additonal keyword "TOOLBAR+" restricts the same search to the
// Toolbar section while "INTERNAL+" matches those commands provided on the Commands
// page of the Customize dialog.
***ACCELERATORS
// Bring up hyperlink dialog
ID_Hyperlink [TOOLBAR+CONTROL+"K"]
// Toggle Orthomode
[CONTROL+"L"]^O
// Next Viewport
[CONTROL+"R"]^V
// ID_Spell ["\"F7\""]
// ID_PanRealti ["\"F11\""]
// ID_ZoomRealt ["\"F12\""]
ID_SelAll [CONTROL+"A"]
ID_Copyclip [TOOLBAR+CONTROL+"C"]
ID_New [TOOLBAR+CONTROL+"N"]
ID_Open [TOOLBAR+CONTROL+"O"]
ID_Print [TOOLBAR+CONTROL+"P"]
ID_Save [TOOLBAR+CONTROL+"S"]
ID_Pasteclip [TOOLBAR+CONTROL+"V"]
ID_Cutclip [TOOLBAR+CONTROL+"X"]
ID_Redo [CONTROL+"Y"]
ID_U [CONTROL+"Z"]
ID_Pickstyle [TOOLBAR+CONTROL+"H"]
// Bring up or close Properties dialog
ID_Modify [TOOLBAR+CONTROL+"1"]
// Bring up or close Design Center dialog
ID_Content [TOOLBAR+CONTROL+"2"]
// Where possible the ID name is the AutoCAD LT command name.
// An ID is no more than 12 characters long.
// Long command names are truncated (not abbreviated) to fit.
// An ID names for a command opion appends the option to the command name:
// Example: the ID for Zoom Window is ID_ZoomWin
// IDs are listed in alphabetical order.
// Helps strings end with a colon, two spaces and the name of the command.
***HELPSTRINGS
ID_3dpoly [Erstellt eine aus Liniensegmenten im 3D-Raum bestehende Polylinie: 3DPOLY]
ID_About [Zeigt Informationen über das Produkt an: INFO]
ID_AddPlotter [Fügt Plotter hinzu und konfiguriert sie]
ID_AddPlStyle [Erstellt eine Plotstiltabelle]
ID_Ai_molc [Macht den Layer eines gewählten Objekts zum aktuellen Layer]
ID_Ai_tiledv [Zeigt die Layout-Optionen für feste Ansichtsfenster an: +AFENSTER]
ID_Arc [Erstellt einen Bogen: BOGEN]
ID_Arc3point [Erstellt einen Bogen anhand dreier Punkte: BOGEN]
ID_ArcCeStAn [Erstellt einen Bogen anhand von Mittel- und Startpunkt sowie eingeschlossenem Winkel: BOGEN]
ID_ArcCeStEn [Erstellt einen Bogen anhand Mittel-, Start- und Endpunkt: BOGEN]
ID_ArcCeStLe [Erstellt einen Bogen anhand Mittel- und Startpunkt sowie Sehnenlänge: BOGEN]
ID_ArcContin [Erstellt einen Bogen, der tangential an die zuletzt gezeichnete Linie oder den letzten Bogen anschließt: BOGEN]
ID_ArcStCeAn [Erstellt einen Bogen anhand Start- und Mittelpunkt sowie eingeschlossenem Winkel: BOGEN]
ID_ArcStCeEn [Erstellt einen Bogen anhand Start-, Mittel- und Endpunkt: BOGEN]
ID_ArcStCeLe [Erstellt einen Bogen anhand von Start- und Mittelpunkt sowie Sehnenlänge: BOGEN]
ID_ArcStEnAg [Erstellt einen Bogen anhand Start- und Endpunkt und eingeschlossenem Winkel: BOGEN]
ID_ArcStEnDi [Erstellt einen Bogen anhand Start- und Endpunkt sowie Startrichtung: BOGEN]
ID_ArcStEnRa [Erstellt einen Bogen anhand Start- und Endpunkt sowie Radius: BOGEN]
ID_Area [Berechnet Fläche und Umfang von Objekten oder von angegebenen Bereichen: FLÄCHE]
ID_Array [Erstellt mehrere Kopien von Objekten in einem Muster: REIHE]
ID_ASSIST [Zeigt das Aktive Hilfe-Fenster an, in dem Sie automatische (oder wahlweise kontextabhängige) Informationen erhalten: ASSIST]
ID_Attdef [Erstellt eine Attributdefinition: ATTDEF]
ID_AttdispNo [Behält die aktuelle Sichtbarkeitseinstellung jedes Attributs bei: ATTZEIG]
ID_AttdispOf [Blendet alle Attribute aus: ATTZEIG AUS]
ID_AttdispOn [Blendet alle Attribute ein: ATTZEIG EIN]
ID_AtteditGlo [Bearbeitet die Variablenattribute eines Blocks: -ATTEDIT]
ID_AtteditSin [Bearbeitet die variablen Attribute eines Blocks: ATTEDIT]
ID_Audit [Prüft den Zustand einer Zeichnung: PRÜFUNG]
ID_AUGI [Startet den Web-Browser und zeigt Informationen zu Benutzergruppen an.]
ID_Back [Navigiert zum vorherigen Hyperlink-Dokument: HYPERLINKZUR]
ID_Base [Legt den Einfügebasispunkt für die aktuelle Zeichnung fest: BASIS]
ID_Bhatch [Füllt eine geschlossene Fläche mit einem Schraffurmuster: GSCHRAFF]
ID_Blockdsc [Ändert die mit einer Blockdefinition verknüpfte Textbeschreibung: BLOCK]
ID_Bmake [Definiert einen Block anhand von ausgewählten Objekten: BLOCK]
ID_Boundary [Erstellt eine Region oder Polylinie aus einer geschlossenen Fläche: UMGRENZUNG]
ID_Browser [Startet den vorgabemäßigen Web-Browser, der in Ihrem Systemregister definiert ist: BROWSER]
ID_BupdateA [Generiert Vorschaubilder für die in AutoCAD DesignCenter angezeigten Blöcke: BLOCKSYMBOL]
ID_BuyOnline [Ermöglicht Online-Käufe: ONLINEKAUF]
ID_Cancel [Bricht den Befehl ab]
ID_Chamfer [Schrägt die Kanten von Objekten ab: FASE]
ID_Circle [Erstellt einen Kreis: KREIS]
ID_Circle2pt [Erstellt einen Kreis anhand zweier Endpunkte des Durchmessers: KREIS]
ID_Circle3pt [Erstellt einen Kreis anhand dreier Punkte auf dem Kreisumfang: KREIS]
ID_CircleDia [Erstellt einen Kreis anhand eines angegebenen Durchmessers: KREIS]
ID_CircleRad [Erstellt einen Kreis anhand eines angegebenen Radius: KREIS]
ID_CircleTTR [Erstellt einen Kreis, der einen angegebenen Radius aufweist und tangential zu zwei Objekten ist: KREIS]
ID_CircleTTT [Erstellt einen Kreis, der tangential zu drei Objekten ist: KREIS]
ID_CKeyboard [Weist Tastaturkurzbefehle den Befehlen zu: ANPASSEN]
ID_CMNonLast [Wiederholt den zuvor ausgeführten Befehl.]
ID_CMSelLast [Wiederholt den zuvor ausgeführten Befehl.]
ID_Content [Verwaltet und fügt Elemente wie Blöcke, XRefs und Schraffurmuster ein: ADCENTER]
ID_Copy [Kopiert Objekte: KOPIEREN]
ID_Copybase [Verdoppelt Objekt mit einem angegebenen Basispunkt: KOPIEBASISP]
ID_Copyclip [Kopiert Objekte in die Windows-Zwischenablage: COPYCLIP]
ID_Copylink [Kopiert die aktuelle Ansicht zur Verknüpfung mit anderen OLE-Anwendungen in die Windows-Zwischenablage: KOPIEVERKNÜPFEN]
ID_CreateLayout [Erstellt ein Layout mit den Einstellungen, die Sie für den Layout-Assistenten eingeben: LAYOUTASS]
ID_CToolbar [Zeigt, erstellt, benennt und entfernt Werkzeugkästen und steuert QuickInfos sowie Schaltflächengrößen: ANPASSEN]
ID_CtrlColor [Setzt die Vorgabe-Farbe für neue Objekte und bearbeitet die Farbe vorhandener Objekte]
ID_CtrlLayer [Setzt den Vorgabe-Layer für neue Objekte; bearbeitet den Layer vorhandener Objekte und schaltet zwischen Layer-Eigenschaften um]
ID_CtrlLinet [Setzt den Vorgabe-Linientyp für neue Objekte und bearbeitet den Linientyp vorhandener Objekte]
ID_CtrlLineW [Stellt die standardmäßige Linienstärke für neue Objekte ein und bearbeitet die Linienstärke bereits vorhandener Objekte]
ID_CtrlPStyl [Setzt den Vorgabe-Plotstil für neue Objekte und ändert den Plotstil vorhandener Objekte]
ID_CtrlRedo [Macht die Ergebnisse eines oder mehrerer ZURÜCK- (Z)-Befehls rückgängig: MZLÖSCH]
ID_CtrlUndo [Macht die letzte Operation rückgängig: Z]
ID_Cutclip [Kopiert Objekte in die Windows-Zwischenablage und entfernt die Objekte aus der Zeichnung: AUSSCHNEIDEN]
ID_Ddattext [Extrahiert Attributdaten: ATTEXT]
ID_Ddcolor [Setzt die Farbe für neue Objekte: FARBE]
ID_Ddedit [Bearbeitet Text, Bemaßungstext und Attributdefinitionen: DDEDIT]
ID_Ddim [Erstellt und ändert Bemaßungsstile: BEMSTIL]
ID_Ddinsert [Fügt einen Block oder eine Zeichnung in die aktuelle Zeichnung ein: EINFÜGE]
ID_Ddptype [Gibt Stil und Größe von Punktobjekten an: DDPTYPE]
ID_Ddrename [Ändert die Namen benannter Objekte: UMBENENN]
ID_Ddrmodes [Stellt Raster- und Fangmodus sowie polaren Objektfang-Modus ein: ZEICHEINST]
ID_Dducs [Verwaltet definierte Benutzerkoordinatensysteme: +BKSMAN]
ID_Dducsp [Verwaltet definierte Benutzerkoordinatensysteme: +BKSMAN]
ID_Ddview [Speichert Ausschnitte unter ihrem Namen und stellt sie wieder her: AUSSCHNT]
ID_Deselectall [Entfernt alle Objekte aus dem Auwahlsatz]
ID_DimAbove [Verschiebt Maßtext über die Maßlinie]
ID_Dimaligne [Erstellt eine ausgerichtete, lineare Bemaßung: BEMAUSG]
ID_Dimangula [Erstellt eine Winkelbemaßung: BEMWINKEL]
ID_Dimbaseli [Erstellt eine Linear-, Winkel- oder Koordinatenbemaßung von der Basislinie der zuletzt erstellten oder gewählten Bemaßung: BEMBASISL]
ID_Dimcenter [Erstellt einen Mittelpunkt oder Mittellinien von Kreisen und Bogen: BEMMITTELP]
ID_Dimcontin [Führt eine Linear-, Winkel- oder Koordinatenbemaßung von der zweiten Hilfslinie der zuletzt erstellten oder gewählten Bemaßung fort: BEMWEITER]
ID_Dimdiamet [Erstellt Durchmesserbemaßungen für Kreise und Bogen: BEMDURCHM]
ID_Dimedit [Bearbeitet Bemaßungen: BEMEDIT]
ID_Dimedito [Ordnet die Hilfslinien von linearen Bemaßungen schräg an: BEMEDIT]
ID_DimHome [Verschiebt Maßtext zurück auf die Vorgabeposition]
ID_Dimlinear [Erstellt Linearbemaßungen: BEMLINEAR]
ID_Dimordina [Erstellt Koordinatenpunkt-Bemaßungen: BEMORDINATE]
ID_Dimoverri [Überschreibt Bemaßungs-Systemvariablen: BEMÜBERSCHR]
ID_DimPrec0 [Setzt den Bemaßungswert auf 0 Dezimalstellen]
ID_DimPrec1 [Setzt den Bemaßungswert auf 1 Dezimalstelle]
ID_DimPrec2 [Setzt den Bemaßungswert auf 2 Dezimalstellen]
ID_DimPrec3 [Setzt den Bemaßungswert auf 3 Dezimalstellen]
ID_DimPrec4 [Setzt den Bemaßungswert auf 4 Dezimalstellen]
ID_DimPrec5 [Setzt den Bemaßungswert auf 5 Dezimalstellen]
ID_DimPrec6 [Setzt den Bemaßungswert auf 6 Dezimalstellen]
ID_Dimradius [Erstellt Radiusbemaßungen für Kreise und Bogen: BEMRADIUS]
ID_DimSty2 [Speichert die Eigenschaften der ausgewählten Bemaßung als neuen Bemaßungsstil]
ID_DimSty3 [Weist den Stil der bzw. den ausgewählten Bemaßungen zu]
ID_DimSty4 [Weist den Stil der bzw. den ausgewählten Bemaßungen zu]
ID_DimSty5 [Weist den Stil der bzw. den ausgewählten Bemaßungen zu]
ID_DimSty6 [Weist den Stil der bzw. den ausgewählten Bemaßungen zu]
ID_DimSty7 [Weist den Stil der bzw. den ausgewählten Bemaßungen zu]
ID_DimSty8 [Weist den Stil der bzw. den ausgewählten Bemaßungen zu]
ID_DimSty9 [Zeigt andere verfügbare Bemaßungsstile]
ID_DimstyleA [Aktualisiert Bemaßungsobjekte mit dem aktuellen Bemaßungsstil: -BEMSTIL]
ID_Dimtedit [Verschiebt und dreht Maßtext: BEMTEDIT]
ID_DimteditA [Dreht Maßtext anhand eines Winkels: BEMTEDIT]
ID_DimteditC [Zentriert Maßtext: BEMTEDIT]
ID_DimteditH [Setzt Maßtext auf seine Vorgabeposition zurück: BEMTEDIT]
ID_DimteditL [Richtet Maßtext links aus: BEMTEDIT]
ID_DimteditR [Richtet Maßtext rechts aus: BEMTEDIT]
ID_DimTxtCen [Verschiebt Maßtext an mittlere Position]
ID_DimTxtMove0 [Verschiebt Maßtext mit Bemaßungslinie]
ID_DimTxtMove1 [Maßtext mit Führung verschieben]
ID_DimTxtMove2 [Nur Maßtext verschieben]
ID_Dist [Mißt Abstand und Winkel zwischen zwei Punkten: ABSTAND]
ID_Divide [Plaziert Punktobjekte oder Blöcke entlang Länge bzw. Umfang eines Objekts: TEILEN]
ID_Dline [Erstellt eine Doppellinie mit Hilfe von geraden Liniensegmenten und Bogen: DLINIE]
ID_Donut [Erstellt gefüllte Kreise und Ringe: RING]
ID_DrawordeA [Plaziert gewählte Objekte so, daß sie vor einem Bezugsobjekt angezeigt werden: DRAWORDER]
ID_DrawordeB [Plaziert gewählte Objekte so, daß sie hinter allen anderen Objekten angezeigt werden: DRAWORDER]
ID_DrawordeF [Plaziert gewählte Objekte so, daß sie vor allen anderen Objekten angezeigt werden: DRAWORDER]
ID_Draworder [Ändert die Anzeigereihenfolge von Bildern und anderen Objekten: ZEICHREIHENF]
ID_DrawordeU [Plaziert gewählte Objekte so, daß sie hinter einem Bezugsobjekt angezeigt werden: DRAWORDER]
ID_Dsviewer [Öffnet das Übersichtsfenster: ÜFENSTER]
ID_Dtext [Zeigt Text während des Eingebens am Bildschirm an: DTEXT]
ID_Dview [Definiert eine Parallelprojektion bzw. eine perspektivische Ansicht: DANSICHT]
ID_DWG_CLOSE [Schließt die aktuelle Zeichnung: SCHLIESSEN]
ID_Ellipse [Erstellt eine Ellipse oder einen elliptischen Bogen: ELLIPSE]
ID_EllipseAr [Erstellt einen elliptischen Bogen: ELLIPSE]
ID_EllipseAx [Erstellt eine Ellipse oder einen elliptischen Bogen: ELLIPSE]
ID_EllipseCe [Erstellt eine Ellipse anhand des festgelegten Mittelpunkts: ELLIPSE]
ID_Enter [Beendet einen Befehl, akzeptiert Befehlswerte und wechselt Griffmodi]
ID_Erase [Entfernt Objekte aus einer Zeichnung: LÖSCHEN]
ID_Explode [Löst ein zusammengesetztes Objekt in seine Bestandteile auf: URSPRUNG]
ID_Export [Speichert Objekte in anderen Dateiformaten: EXPORT]
ID_Extend [Dehnt ein Objekt so, daß es auf ein anderes Objekt trifft: DEHNEN]
ID_Fillet [Fast die Kanten von Objekten bzw. rundet sie ab: ABRUNDEN]
ID_Filter [Erstellt schnell Auswahlsätze basierend auf Filterkriterien: SAUSWAHL]
ID_Forward [Navigiert zum nächsten Hyperlink-Dokument: HYPERLINKVOR]
ID_From [Ermittelt einen Punktversatz von einem Referenzpunkt innerhalb eines Befehls: FROM]
ID_GotoURL [Lädt den Web-Browser und und sucht nach der im gewählten Objekt eingebetteten Adresse: GEHEZUURL]
ID_GripBase [Legt den Einfügebasispunkt für die aktuelle Zeichnung fest: BASIS]
ID_GripCopy [Kopiert Objekte: KOPIEREN]
ID_GripExit [Verläßt den Griffbearbeitungsmodus und bringt Sie zur Befehlszeile zurück: EXIT]
ID_GripMirro [Erstellt ein Spiegelbild von Objekten: SPIEGELN]
ID_GripMove [Verschiebt Objekte in eine angegebene Richtung und um einen angegebenen Abstand: SCHIEBEN]
ID_GripRefer [Legt den Bezugspunkt fest: REFERENZ]
ID_GripRotat [Verschiebt Objekte in bezug auf einen Basispunkt: DREHEN]
ID_GripScale [Vergrößert oder verkleinert Objekte proportional in die X-, Y- und Z-Richtung: VARIA]
ID_GripStret [Verschiebt oder streckt Objekte: STRECKEN]
ID_GripUndo [Macht die letzte Operation rückgängig: Z]
ID_Group [Erstellt einen benannten Auswahlsatz von Objekten: GRUPPE]
ID_GroupDlg [Verwaltet gespeicherte Sätze von Objekten, die als Gruppen bezeichnet werden: GRUPPE]
ID_Hatchedit [Ändert ein bereits bestehendes Schraffurobjekt: SCHRAFFEDIT]
ID_Help [Zeigt die Online-Hilfe an: HILFE]
ID_Hide [Regeneriert ein 3D-Modell mit unterdrückten verdeckten Linien: VERDECKT]
ID_HlnkBack [Geht zum vorherigen über Hyperlink verknüpften Dokument: HYPERLINKZUR]
ID_HlnkFwd [Geht zum nächsten über Hyperlink verknüpften Dokument: HYPERLINKVOR]
ID_HlnkStop [Hebt die aktuelle Naviagtionsrichtung auf: HYPERLINKSTOP]
ID_Hyperlink [Ordnet einem Objekt einen Hyperlink zu oder ändert einen vorhandenen Hyperlink: HYPERLINK]
ID_Id [Zeigt die Koordinatenwerte einer Position an: ID]
ID_Image [Listet und ändert Pfadangaben der in die Zeichnungsdatei eingefügten Bilder: BILD]
ID_Imagefram [Steuert, ob Bildrahmen ein- oder ausgeblendet werden: BILDRAHMEN]
ID_Import [Liest verschiedene Dateiformate ein: IMPORT]
ID_ImpPlotSet [Zeigt einen Assistenten an, um Plot-Einstellungen der PCP- und PC2-Konfigurationsdatei in die Registerkarte Modell oder das aktuelle Layout zu importieren: PCINWIZARD]
ID_Insertobj [Fügt ein verknüpftes oder eingebettetes Objekt ein: OBJEINF]
ID_Intersect [Verbindet ausgewählte Regionen durch Überschneidung: SCHNITTMENGE]
ID_Layer [Verwaltet Layer und Layer-Eigenschaften: LAYER]
ID_LayNew [Erstellt eine neue Layout-Registerkarte: -LAYOUT]
ID_LayoutWiz [Erstellt eine neue Layout-Registerkarte und legt Seiten- sowie Plottereinstellungen fest: LAYOUTASS]
ID_LayTemp [Zeigt das Dialogfeld Datei wählen, aus dem eine vorhandene Vorlage als Basis für das neue Layout gewählt werden kann: -LAYOUT]
ID_Leader [Erstellt eine Führung und Maßtexte für Führungen: SFÜHRUNG]
ID_Lengthen [Ändert die Länge von Objekten und den eingeschlossenen Winkel von Bogen: LÄNGE]
ID_Limits [Stellt die Limiten der Rasteranzeige in der aktuellen Modell- oder Layout-Registerkarte ein: LIMITEN]
ID_Line [Erstellt gerade Liniensegmente: LINIE]
ID_Linetype [Lädt und setzt Linientypen: LINIENTYP]
ID_Linewt [Stellt die aktuelle Linienstärke, Optionen für die Anzeige von Linienstärken und Linienstärkeeinheiten ein: LSTÄRKE]
ID_Links [Aktualisiert und ändert bestehende OLE-Verknüpfungen oder hebt sie auf: OLEVERKN]
ID_List [Zeigt Datenbankinformationen für gewählte Objekte an: LISTE]
ID_MARKUP [Fügt Markierungen von einer RML-Datei ein: RMLIN]
ID_Massprop [Berechnet die Masseneigenschaften von Regionen oder von AutoCAD-3D-Volumenkörpern: MASSEIG]
ID_Matchprop [Wendet die Eigenschaften eines gewählten Objekts auf andere Objekte an: EIGANPASS]
ID_Measure [Plaziert Punktobjekte oder Blöcke in gleichmäßigen Abständen auf einem Objekt: MESSEN]
ID_MeetNow [Macht die aktuelle Sitzung der Anwendung für mehrere Benutzer im Netzwerk zugänglich: BESPRECHUNG]
ID_Menuload [Lädt Teilmenüdateien: MENÜLAD]
ID_Mirror [Erstellt ein Spiegelbild von Objekten: SPIEGELN]
ID_Modify [Steuert Eigenschaften bestehender Objekte: EIGENSCHAFTEN]
ID_Move [Verschiebt Objekte in eine angegebene Richtung und um einen angegebenen Abstand: SCHIEBEN]
ID_MRU [Öffnet diese Zeichnung]
ID_Mtedit [Öffnet den MText-Editor für das ausgewählte Mtext-Objekt: MTBEARB]
ID_Mtext [Erstellt ein Multilinien-Textobjekt: MTEXT]
ID_New [Erstellt eine neue Zeichnungsdatei: NEU]
ID_NewLayout [Erstellt und ändert die Layout-Registerkarten einer Zeichnung: LAYOUT]
ID_Offset [Erstellt konzentrische Kreise, parallele Linien und parallele Kurven: VERSETZ]
ID_Open [Öffnet eine bestehende Zeichnungsdatei: ÖFFNEN]
ID_Osnap [Aktiviert den Objektfangmodus: OFANG]
ID_OsnapAppa [Fängt den angenommenen Schnittpunkt zweier Objekte: ANP]
ID_OsnapCent [Fängt das Zentrum eines Bogens, eines Kreises, einer Ellipse oder eines elliptischen Bogens: ZEN]
ID_OsnapEndp [Fängt den nächsten Endpunkt eines Objekts: END]
ID_OsnapInse [Fängt den Basispunkt von Objekten, z.B. von Text, Block oder Attribut: BAS]
ID_OsnapInte [Fängt den Schnittpunkt zweier Objekte: SCHN]
ID_OsnapMidp [Fängt den Mittelpunkt eines Objekts: MIT]
ID_OsnapNear [Fängt den nächsten Punkt eines Objekts: NÄCH]
ID_OsnapNode [Fängt ein Punktobjekt: PUNKT]
ID_OsnapNone [Unterdrückt den aktiven Objektfang für die aktuelle Auswahl: KEI]
ID_OsnapPara [Fängt parallel zu einer angegebenen Linie: PAR]
ID_OsnapPerp [Fängt einen lotrechten Punkt zu einem Objekt: LOT]
ID_OsnapQuad [Fängt einen Quadranten eines Bogens, eines Kreises, einer Ellipse oder eines elliptischen Bogens: QUAD]
ID_OsnapTang [Fängt die Tangente eines Bogens, eines Kreises, einer Ellipse eines elliptischen Bogens oder einer Polylinie: TAN]
ID_Pan [Verschiebt die Ansicht im aktuellen Ansichtsfenster: PAN]
ID_PanDown [Verschiebt die Ansicht nach unten: PAN]
ID_PanLeft [Verschiebt die Ansicht nach links: PAN]
ID_PanPick [Verschiebt die Ansicht um den angegebenen Abstand: -PAN]
ID_PanRight [Verschiebt die Ansicht nach rechts: PAN]
ID_PanUp [Verschiebt die Ansicht nach oben: PAN]
ID_Pastebloc [Fügt einen kopierten Block in eine neue Zeichnung ein: BLOCKEINFÜG]
ID_Pasteclip [Fügt Daten aus der Windows-Zwischenablage ein: CLIPEINFÜG]
ID_Pastehlnk [Fügt einen Hyperlink in das ausgewählte Objekt ein: ALSHYPERLINKEINFÜGEN]
ID_Pasteorig [Fügt ein kopiertes Objekt in eine neue Zeichnung ein, wobei die Koordinaten der Originalzeichnung verwendet werden: ORIGEINÜG]
ID_Pastesp [Fügt Daten aus der Windows-Zwischenablage ein und steuert das Datenformat: INHALTEINGÜG]
ID_Pedit [Bearbeitet Polylinien: PEDIT]
ID_PenSetting [Erstellt eine farbabhängige Plotstiltabelle: R14STIFTEINSTASS]
ID_Pickstyle [Schaltet die Gruppenauswahl ein oder aus: PICKSTYLE]
ID_PlanCurre [Zeigt die Draufsicht in einem BKS an: DRSICHT]
ID_PlanUCS [Zeigt die Draufsicht eines vorher gespeicherten BKS an: DRSICHT]
ID_PlanWorld [Zeigt die Draufsicht im WKS an: DRSICHT]
ID_Pline [Erstellt 2D-Polylinien: PLINIE]
ID_PlotMgr [Zeigt den Plot-Manager an, von dem aus Sie den Assistenten zum Hinzufügen eines Plotters und den Plotterkonfigurations-Editor starten können: PLOTTERMANAGER]
ID_PlotSetup [Legt die Layout-Seite, den Plotter, das Papierformat und die Einstellungen für jedes neue Layout fest: SEITEEINRICHTEN]
ID_PlotStyle [Bestimmt den aktuellen Plotstil für neue Objekte bzw. den zugewiesenen Plotstil für ausgewählte Objekte: PLOTSTIL]
ID_PlotStyMgr [Greift auf den Assistenten zum Hinzufügen einer Plotstiltabelle und den Plotstiltabellen-Editor zu: PLOTSTILMANAGER]
ID_PointA [Zeigt Autodesk Point A im Vorgabe-Browser an: BROWSER]
ID_PointFilx [Bestimmt einen .X-Punktfilter: .X]
ID_PointFily [Bestimmt einen .Y-Punktfilter: .Y]
ID_PointFilz [Bestimmt einen .Z-Punktfilter: .Z]
ID_PointFixy [Bestimmt einen .XY-Punktfilter: .XY]
ID_PointFixz [Bestimmt einen .XZ-Punktfilter: .XZ]
ID_PointFiyz [Bestimmt einen .YZ-Punktfilter: .YZ]
ID_PointMult [Erstellt mehrere Punktobjekte: PUNKT]
ID_PointSing [Erstellt ein Punktobjekt: PUNKT]
ID_Polygon [Erstellt eine gleichseitige, geschlossene Polylinie: POLYGON]
ID_Preferenc [Legt Einstellungen benutzerspezfisch fest: Optionen]
ID_Preview [Zeigt die Darstellung der Zeichnung an, wenn sie gedruckt oder geplottet wird: VORANSICHT]
ID_Print [Gibt Zeichnung an Plotter, Drucker oder Datei aus: PLOT]
ID_ProdSupp [Greift auf die Autodesk-Produkt-Support-Site von Point A zu]
ID_Props [Bestimmt die Dateieigenschaften der aktuellen Zeichnung und zeigt sie an: DWGEIGEN]
ID_Publish [Erstellt HTML-Seiten, die Symbole der ausgewählten Zeichnungen enthalten: IMWEBPUBLIZIEREN]
ID_Purge [Entfernt nicht verwendete Elemente wie Blockdefinitionen und Layer aus der Zeichnung: BEREINIG]
ID_QkGroup [Erstellt eine unbenannte Gruppe mit Hilfe von ausgewählten Objekten: -GRUPPE]
ID_QkUnGroup [Entfernt eine Gruppendefinition aus der Zeichnung: SGRUPPEAUFHEB]
ID_Qselect [Erstellt schnell Auswahlsätze basierend auf Filterkriterien: SAUSWAHL]
ID_Ray [Erstellt eine einseitig unendliche Linie: STRAHL]
ID_Recover [Stellt eine beschädigte Zeichnung wieder her: WHERST]
ID_Rectang [Erstellt eine rechteckige Polylinie: RECHTECK]
ID_Redo [Macht die Ergebnisse eines oder mehrerer ZURÜCK- (Z-) Befehle rückgängig: MZLÖSCH]
ID_Regen [Regeneriert die gesamte Zeichnung von der Zeichnungsdatenbank: REGEN]
ID_RegenAll [Regeneriert die Zeichnung und zeichnet alle Ansichtsfenster neu: REGENALL]
ID_Region [Konvertiert ein Objekt, das einen Bereich einschließt, in ein Regionen-Objekt: REGION]
ID_Revcloud [Erstellt eine Polylinie mit mehreren Bogen, die eine Wolkenform bilden: REVWOLKE]
ID_Revdate [Fügt einen Block, der einen Benutzernamen, die aktuelle Zeit und das Datum sowie den Zeichnungsnamen enthält, ein oder aktualisiert ihn: REVDATE]
ID_Rotate [Dreht Objekte um einen Basispunkt: DREHEN]
ID_Save [Speichert die aktuelle Zeichnung: KSICH]
ID_Saveas [Speichert eine Kopie der aktuellen Zeichnung unter einem neuen Dateinamen: SICHALS]
ID_Scale [Vergrößert oder verkleinert Objekte proportional in die X-, Y- und Z-Richtung: VARIA]
ID_Script [Führt eine Programmsequenz gemäß einer Skriptdatei aus: SCRIPT]
ID_SelAll [Wählt alle Objekte auf getauten Layern]
ID_SendMail [Sendet die aktuelle Zeichnungsdatei als E-Mail-Anhang oder FAX: SENDMAIL]
ID_Shade0 [Zeigt ein schattiertes Bild der Zeichnung im aktuellen Ansichtsfenster mit 256 Farben an: SHADE]
ID_Shade1 [Zeigt ein schattiertes Bild der Zeichnung im aktuellen Ansichtsfenster mit 256 Farben und hervorgehobenen Kanten an: SHADE]
ID_Shade2 [Zeigt ein Bild der Zeichnung im aktuellen Ansichtsfenster mit entfernten verdeckten Linien an: SHADE]
ID_Shade3 [Zeigt ein schattiertes Bild der Zeichnung im aktuellen Ansichtsfenster mit 16 Farben an: SHADE]
ID_Spell [Überprüft die Rechtschreibung eines ausgewählten Textes: RECHTSCHREIBUNG]
ID_Spline [Erstellt eine NURBS-Kurve: SPLINE]
ID_Splinedit [Bearbeitet einen Spline oder eine Spline-angeglichene Polylinie: SPLINEEDIT]
ID_Stop [Bricht die aktuelle Navigationsauswahl ab: HYPERLINKSTOP]
ID_Stretch [Verschiebt oder streckt Objekte: STRECKEN]
ID_Style [Erstellt oder ändert benannte Textstile in Ihrer Zeichnung und legt sie fest: STIL]
ID_Subtract [Verbindet ausgewählte Regionen durch Subtraktion: DIFFERENZ]
ID_Support [Stellt technischen Support und Fehlerbehebungs-Tips zur Verfügung]
ID_TabletCal [Kalibriert den Digitalisierer auf das Koordinatensystem der Zeichnung: TABLETT]
ID_TabletCfg [Bestimmt den Tablettmenübereich oder richtet ihn neu aus: TABLETT]
ID_TabletOff [Schaltet den Tablettmodus aus: TABLETT]
ID_TabletOn [Schaltet den Tablettmodus ein: TABLETT]
ID_TbDimensi [Werkzeugkasten Bemaßung]
ID_TbDraw [Werkzeugkasten Zeichnen]
ID_TbGroup [Werkzeugkasten Gruppieren]
ID_TbInquiry [Werkzeugkasten Abfrage]
ID_TbInsert [Werkzeugkasten Einfügen]
ID_TbLayouts [Werkzeugkasten Layouts]
ID_TbModifII [Werkzeugkasten Ändern II]
ID_TbModify [Werkzeugkasten Ändern]
ID_TbObjectP [Werkzeugkasten Eigenschaften]
ID_TbOsnap [Werkzeugkasten Objektfang]
ID_TbReferen [Werkzeugkasten Referenz]
ID_TbStandar [Standard-Funktionsleiste]
ID_TbUcs [Werkzeugkasten BKS]
ID_TbUcsName [BKS II-Werkzeugkasten]
ID_TbViewpoi [Werkzeugkasten Ansicht]
ID_TbVpCreat [Werkzeugkasten Ansichtsfenstererstellung]
ID_TbWeb [Werkzeugkasten Internet]
ID_TbZoom [Werkzeugkasten Zoom]
ID_TextFind [Sucht, ersetzt, wählt oder zoomt den angegebenen Text: TEXTSUCHE]
ID_Textscr [Öffnet das Textfenster: TEXTBLD]
ID_Thickness [Legt die aktuelle 3D-Objekthöhe fest: THICKNESS]
ID_Time [Zeigt eine Statistik der aktuellen Zeichnung mit Datum und Zeit an: ZEIT]
ID_TmplLayou [Fügt ein neues Layout basierend auf einer vorhandenen Layout-Vorlage ein: LAYOUT]
ID_Today [Öffnet das Fenster Aktuell: AKTUELL]
ID_Tolerance [Erstellt geometrische Toleranzen: TOLERANZ]
ID_Toolbar [Blendet Werkzeugkästen ein und aus und gleicht sie benutzerspezifisch an: WERKZEUGKASTEN]
ID_Tracking [Ermittelt einen Punkt unter einer Reihe temporärer Punkte: SPUR]
ID_Trim [Stutzt Objekte anhand einer durch andere Objekte definierten Schnittkante: STUTZEN]
ID_U [Macht die letzte Aktion rückgängig: Z]
ID_Ucs [Verwaltet Benutzerkoordinatensysteme: BKS]
ID_Ucs3point [Legt den neuen BKS-Ursprung und die Richtung der X- und Y-Achse fest: BKS]
ID_UcsBack [Gibt die BKS-Ausrichtung nach hinten an: BKS]
ID_UcsBottom [Gibt die BKS-Ausrichtung nach unten an: BKS]
ID_UcsCombo [Ändert das BKS]
ID_UcsFace [Bestimmt ein neues Koordinatensystem aufgrund einer gewählten Fläche: BKS]
ID_UcsFront [Gibt die BKS-Ausrichtung nach vorne an: BKS]
ID_UcsiconOn [Steuert die Sichtbarkeit und Plazierung des BKS-Symbols: BKSYMBOL]
ID_UcsiconOr [Zeigt das BKS-Symbol am Ursprung des BKS an: BKSYMBOL]
ID_UcsiconPr [Steuert den Stil, die Größe und die Farbe des BKS-Symbols: BKSYMBOL]
ID_UcsLeft [Gibt die BKS-Ausrichtung nach links an: BKS]
ID_UcsMove [Verschiebt das definierte BKS: BKS]
ID_UcsObject [Bestimmt ein neues Koordinatensystem aufgrund eines gewählten Objekts: BKS]
ID_UcsOrigin [Definiert ein neues BKS durch Verschieben des Ursprungs: BKS]
ID_UcsPrevio [Stellt das vorherige BKS wieder her: BKS]
ID_UcsRight [Gibt die BKS-Ausrichtung nach rechts an: BKS]
ID_UcsTop [Gibt die BKS-Ausrichtung nach oben an: BKS]
ID_UcsView [Bestimmt ein neues Koordinatensystem mit der XY-Ebene parallel zum Bildschirm: BKS]
ID_UcsWorld [Setzt das BKS auf das Weltkoordinatensystem: BKS]
ID_UcsXAxRot [Dreht das aktuelle BKS um die X-Achse: BKS]
ID_UcsYAxRot [Dreht das aktuelle BKS um die Y-Achse: BKS]
ID_UcsZAxRot [Dreht das aktuelle BKS um die Z-Achse: BKS]
ID_UcsZAxVec [Definiert ein BKS mittels Extrusion entlang einer positiven Z-Achse: BKS]
ID_Union [Verbindet ausgewählte Regionen durch Hinzufügen: VEREINIG]
ID_Units [Steuert die Anzeige von Koordinaten und Winkeln und die Genauigkeit: EINHEIT]
ID_VpClip [Schneidet ein Papierbereichsansichtsfenster zu: AFZUSCHNEIDEN]
ID_VpConvert [Konvertiert ein Objekt in ein Papierbereichsansichtsfenster: -AFENSTER]
ID_VpDialog [Zeigt das Dialogfeld Ansichtsfenster an: AFENSTER]
ID_VpointBac [Setzt den Ansichtspunkt hinten: AUSSCHNT]
ID_VpointBot [Setzt den Ansichtspunkt unten: AUSSCHNT]
ID_VpointFro [Setzt den Ansichtspunkt vorne: AUSSCHNT]
ID_VpointLef [Setzt den Ansichtspunkt links: AUSSCHNT]
ID_VpointNE [Setzt den Ansichtspunkt auf Isometrieansicht Nordost: AUSSCHNT]
ID_VpointNW [Setzt den Ansichtspunkt auf Isometrieansicht Nordwest: AUSSCHNT]
ID_VpointRig [Setzt den Ansichtspunkt rechts: AUSSCHNT]
ID_VpointSE [Setzt den Ansichtspunkt auf Isometrieansicht Südost: AUSSCHNT]
ID_VpointSW [Setzt den Ansichtspunkt auf Isometrieansicht Südwest: AUSSCHNT]
ID_VpointTop [Setzt den Ansichtspunkt oben: AUSSCHNT]
ID_VpointTri [Zeigt Kompaß und Achsendreifuß zur Definition einer Ansichtsrichtung im Modellbereich an: APUNKT]
ID_Vport_dispoff [Blendet ein Ansichtsfenster aus und macht seine Objekte unsichtbar: -AFENSTER]
ID_Vport_dispon [Zeigt ein Ansichtsfenster, aktiviert es und macht seine Objekte sichtbar: -AFENSTER]
ID_Vport_hideoff [Deaktiviert die Funktion zum Entfernen von verdeckten Linien aus einem Ansichtsfenster während des Plottens: -AFENSTER]
ID_Vport_hideon [Entfernt verdeckte Linien aus einem Ansichtsfenster beim Plotten aus dem Papierbereich: -AFENSTER]
ID_Vport_lockoff [Entsperrt das aktuelle Ansichtsfenster: -AFENSTER]
ID_Vport_lockon [Sperrt das aktuelle Ansichtsfenster und ist vergleichbar mit der Layer-Sperre: -AFENSTER]
ID_Vports2 [Erstellt zwei gleiche Ansichtsfenster: -AFENSTER]
ID_Vports3 [Erstellt drei Ansichtsfenster: -AFENSTER]
ID_Vports4 [Erstellt vier Ansichtsfenster gleicher Größe: -AFENSTER]
ID_VportsJoi [Faßt zwei benachbarte Ansichtsfenster in einem einzigen zusammen: -AFENSTER]
ID_VportsSav [Öffnet ein neues Ansichtsfenster unter Verwendung eines angegebenen Namens: +AFENSTER]
ID_VportsSin [Zeigt die Zeichnung wieder in einem einzigen Ansichtsfenster an und verwendet die Ansicht des aktuellen Ansichtsfensters: AFENSTER]
ID_VPScale [Stellt die Ansichtsfensterskalierung für neue Objekte ein und bearbeitet die Ansichtsfensterskalierung vorhandener Ansichtsfenster]
ID_VpSingle [Erstellt ein einzelnes Papierbereichsansichtsfenster: -AFENSTER]
ID_WhatsNew [Beschreibt neues Feature in diesem Produkt]
ID_WinArg [Ordnet Zeichnungsfenster-Symbole an: SYSFENSTER]
ID_WinCas [Ordnet Zeichnungsfenster überlappend an: SYSFENSTER]
ID_WinHor [Ordnet Zeichnungsfenster horizontal und nichtüberlappend an: SYSFENSTER]
ID_WinVrt [Ordnet Zeichnungsfenster vertikal und nichtüberlappend an: SYSFENSTER]
ID_Wmfin [Liest eine Datei in Windows-Metadatei-Format ein: WMFIN]
ID_Xattach [Ordnet eine externe Referenz einer aktuellen Zeichnung zu: XZUORDNEN]
ID_Xbind [Bindet abhängige Symbole einer XRef an die aktuelle Zeichnung: XBINDEN]
ID_Xclipfram [Steuert die Anzeige der XRef- oder Block-Zuschneide-Umgrenzungen: XCLIPFRAME]
ID_Xline [Erstellt eine unendliche Linie: KLINIE]
ID_Xref [Steuert externe Referenzen zu Zeichnungsdateien: XREF]
ID_XrefClip [Definiert eine Zuschneide-Umgrenzung einer externen Referenz oder eines Blocks und legt die vorderen oder hinteren Zuschneideebenen fest: XZUSCHNEIDEN]
ID_ZoomAll [Zoomt auf den Zeichnungsrand oder die Rasterlimiten: ZOOM]
ID_ZoomCente [Zoomt, um eine durch Mittelpunkt und Vergrößerung bzw. Höhe festgelegte Ansicht anzuzeigen: ZOOM]
ID_ZoomDynam [Zoomt auf die Anzeige des generierten Teils der Zeichnung: ZOOM]
ID_ZoomExten [Zoomt bis zu den Zeichnungsgrenzen: ZOOM]
ID_ZoomIn [Zoomt, um die sichtbare Größe von Objekten zu steigern: ZOOM]
ID_ZoomOut [Zoomt, um die sichtbare Größe von Objekten zu verringern: ZOOM]
ID_ZoomPrevi [Zoomt auf die vorherige Ansicht: ZOOM]
ID_ZoomRealt [Zoomt, um die sichtbare Größe von Objekten in der aktuellen Ansicht zu steigern oder zu verringern: ZOOM]
ID_ZoomScale [Zoomt die Anzeige mit einem festgelegten Zoomfaktor: ZOOM]
ID_ZoomWindo [Zoomt auf eine durch ein rechteckiges Fenster definierte Anzeige: ZOOM]
ID_BreakSele [Bricht ein gewähltes Objekt an einem bestimmten Punkt: BRUCH]
ID_LayerP [Stellt die vorherigen Layereinstellunen wieder her: VLAYER]
ID_Dimreasso [Verknüpft die gewählten Bemaßungen mit Objekten oder Punkten auf Objekten bzw. stellt diese Verknüpfungen wieder her: BEMREASSOZ]
ID_Scaletext [Skaliert die gewählten Textobjekte: SKALTEXT]
ID_Justifyte [Legt die Ausrichtung für den gewählten Text fest: ZENTRTEXTAUSRICHT]
ID_Spacetran [Konvertiert Entfernungen oder Höhen vom Modell- in den Papierbereich und umgekehrt: BEREICHKONV]
ID_Etransmit [Erstellt ein Übertragungspaket aus einer Zeichnung und zugehörigen Dateien: ETRANSMIT]
ID_Redrawall [Zeichnet alle Ansichtsfenster neu: NEUZALL]
ID_Ddvpoint [Legt die dreidimensionale Ansichtsrichtung fest: DDVPOINT]
ID_Break [Teilt das ausgewählte Objekt zwischen zwei Punkten auf: BRUCH]
