wie hilfreich doch die Autodesk KnowledgeBase sein kann. Eine Sache von 10 Sek...
Hier die Antwort:
Compatibility of Autodesk software-locked products with Microsoft® Windows® XP
Print ID: TS68252
Applies to: AutoCAD® 2002
Published Date: 10/31/2001
Issue
When you try to run Autodesk products that are locked using the Ç-Dilla based security system on Microsoft® Windows® XP, you receive the following warning message:
Cdilla CDSecure. This version of CDSecure is not compatible with this version of Windows.
If you attempt to run the program, license errors are subsequently displayed and the product does not start.
Solution
The updated runtime system (RTS) version 3.24.000 is required to run software-locked Autodesk products on Windows XP. Download the rts324000.exe file at the Autodesk Product Support website.
Only software-locked Autodesk products require this update. The versions of the products using FLEXlm® license manager technology do not require the updated RTS.
Alles klar?
Ciao,
Marc
