Thema: Auswahl für 3D zu 2D Polylinie (732 mal gelesen)
silcono Mitglied Planer
Beiträge: 88 Registriert: 19.12.2014 AutoCAD 2010 LT AutoCAD 2014 AutoCAD 2018 AutoCAD MAP 3D 2017 Intel(R) Core(TM) i5-4570 CPU @ 3.20GhZ 3.20Ghz 16,00GB Ram Windows 7- Prof. 64-Bit ASUS EAH6450 Series
erstellt am: 05. Dez. 2018 06:50 <-- editieren / zitieren --> Unities abgeben:
Hallo zusammen, zu kurzen Erklärung: ich bekomme aus eine Datei. Diese enthält 3D-Poylinien und diese will ich zu 2D-Polylinien konvertieren. Ich habe hierfür auch schon eine kleine Routine von Tony Hotchkiss im Netz gefunden: Code:
(defun pline-3d-2d () (vl-load-com) (setq *thisdrawing* (vla-get-activedocument (vlax-get-acad-object) ) ;_ end of vla-get-activedocument *modelspace* (vla-get-ModelSpace *thisdrawing*) ) ;_ end of setq (setq 3d-pl-list (get-3D-pline) ) ;_ end of setq (if 3d-pl-list (progn (setq vert-array-list (make-list 3d-pl-list)) (setq n (- 1)) (repeat (length vert-array-list) (setq vert-array (nth (setq n (1+ n)) vert-array-list)) (setq lyr (vlax-get-property (nth n 3d-pl-list) 'Layer)) (setq obj (vla-AddPolyline *modelspace* vert-array)) (vlax-put-property obj 'Layer lyr) ) ;_ end of repeat (foreach obj 3d-pl-list (vla-delete obj)) ) ;_ end of progn ) ;_ end of if ) ;_ end of pline-3d-2d(defun get-3D-pline () (setq pl3dobj-list nil obj nil 3d "AcDb3dPolyline" ) ;_ end of setq (setq selsets (vla-get-selectionsets *thisdrawing*)) (setq ss1 (vlax-make-variant "ss1")) (if (= (vla-get-count selsets) 0) (setq ssobj (vla-add selsets ss1)) ) ;_ end of if (vla-clear ssobj) (setq Filterdata (vlax-make-variant "POLYLINE")) (setq no-ent 1) (while no-ent (vla-Selectonscreen ssobj) (if (> (vla-get-count ssobj) 0) (progn (setq no-ent nil) (setq i (- 1)) (repeat (vla-get-count ssobj) (setq obj (vla-item ssobj (vlax-make-variant (setq i (1+ i))) ) ;_ end of vla-item ) ;_ end of setq (cond ((= (vlax-get-property obj "ObjectName") 3d) (setq pl3dobj-list (append pl3dobj-list (list obj)) ) ;_ end of setq ) ) ;_ end-of cond ) ;_ end of repeat ) ;_ end of progn (prompt "\nNo entities selected, try again.") ) ;_ end of if (if (and (= nil no-ent) (= nil pl3dobj-list)) (progn (setq no-ent 1) (prompt "\nNo 3D-polylines selected.") (quit) ) ;_ end of progn ) ;_ end of if ) ;_ end of while (vla-delete (vla-item selsets 0)) pl3dobj-list ) ;_ end of get-3D-pline (defun get-3D-pline-old () (setq no-ent 1) (setq filter '((-4 . "<AND") (0 . "POLYLINE") (70 . 8) (-4 . "AND>") ) ) ;_ end of setq (while no-ent (setq ss (ssget filter) k (- 1) pl3dobj-list nil obj nil 3d "AcDb3dPolyline" ) ;_ end-of setq (if ss (progn (setq no-ent nil) (repeat (sslength ss) (setq ent (ssname ss (setq k (1+ k))) obj (vlax-ename->vla-object ent) ) ;_ end-of setq (cond ((= (vlax-get-property obj "ObjectName") 3d) (setq pl3dobj-list (append pl3dobj-list (list obj)) ) ;_ end of setq ) ) ;_ end-of cond ) ;_ end-of repeat ) ;_ end-of progn (prompt "\nNo 3D-polylines selected, try again.") ) ;_ end-of if ) ;_ end-of while pl3dobj-list ) ;_ end of get-3D-pline-old
(defun make-list (p-list) (setq i (- 1) vlist nil calist nil ) ;_ end of setq (repeat (length p-list) (setq obj (nth (setq i (1+ i)) p-list) coords (vlax-get-property obj "coordinates") ca (vlax-variant-value coords) ) ;_ end-of setq (setq calist (append calist (list ca))) ) ;_ end-of repeat ) ;_ end-of make-list (defun c l32 () (pline-3d-2d) (princ) ) ;_ end of pl32 (prompt "Enter PL32 to start: ")
Ein bisschen Lispeln kann ich, aber mit vla, vlax...usw. da bin ich erst noch am werden. Ich möchte jetzt eine Auswahl schon innerhalb der Lisp anwenden, wie z.B.: Code:
(setq 3dpoly (ssget "X" '((0 . "Polyline")(8 . "meinLayer"))))
Eventuell bin ich in der Funktion "get-3D-pline" oder "get-3D-pline-old" richtig, aber wie ich das verbaue, da bräuchte ich ein bisschen Unterstützung. Im Voraus besten Dank und einen guten Start in den Tag! Grüße Silcono Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
joern bosse Ehrenmitglied Dipl.-Ing. Vermessung
Beiträge: 1734 Registriert: 11.10.2004 Window 10 ACAD 2021 CIVIL 2021 BricsCAD V14-V22 Intel(R) Core(TM)i5-8250U CPU @ 1.60GHz 1.80 GHz 16.0GB RAM NVIDIA GeForce GTX 1050<P>
erstellt am: 05. Dez. 2018 08:14 <-- editieren / zitieren --> Unities abgeben: Nur für silcono
Hallo Silcono, ich habe ein Beispiel geschrieben, wie aus einer 3D-Polylinie eine LW-Polylinie wird. Zu beachten: die Höheninformationen der einzelnen Stützpunkte gehen verloren, die Erhebung der neuen LW-Polylinie ist 0.0. Aber Du kannst es Dir mal anschauen und anpassen. Ich habe einen schnellen Test gemacht, scheint zu funktionieren: Code:
(defun c:3pl2Lw ( / AWS AWSLIST SPACE VLA-OBJ) (if (and(setq aws (ssget (list (cons 0 "POLYLINE")))) (setq awsList (JB_3pl2lw:awsList aws))) (progn (setq space(vla-get-modelSpace (vla-get-activeDocument (vlax-get-acad-object)))) (mapcar '(lambda(vla-obj) (vla-addLightweightPolyline space (JB_3pl2Lw:coordinates:array vla-obj)) (vla-put-layer (vlax-ename->vla-object(entlast)) (vla-get-layer vla-obj)) ;;;Hier können noch weitere Eigenschaften übertragen werden, z.B. ;;;Closed, Lineweigth, ... (vla-delete vla-obj) ) awsList)) (alert "keine 3D-Polylinien ausgewählt.") ) (princ)) (defun JB_3pl2lw:awsList (aws / N RETLIST) (setq n 0) (repeat (sslength aws) (if (=(vla-get-Objectname (vlax-ename->vla-object(ssname aws n)))"AcDb3dPolyline") (setq RetList (cons (vlax-ename->vla-object(ssname aws n)) RetList))) (setq n (+ n 1))) RetList)
(defun JB_3pl2Lw:coordinates:array (vla-obj / KOORDSARRAY N RETLIST SUB X) (setq n 0) (mapcar '(lambda(X) (setq n (+ n 1)) (if (= n 3) (setq RetList (cons (reverse Sub)RetList) n 0 Sub nil) (setq Sub (cons X Sub)))) (vlax-get vla-obj 'Coordinates)) (setq RetList(reverse RetList)) (setq KoordsArray (vlax-make-safearray vlax-vbDouble (cons 0 (-(*(length RetList)2)1)))) (vlax-safearray-fill KoordsArray (apply 'append RetList)) )
------------------ viele Grüße Jörn http://www.bosse-engineering.com Foto-Manager Youtube Eine Antwort auf diesen Beitrag verfassen (mit Zitat/Zitat des Beitrags) IP |
erstellt am: 05. Dez. 2018 09:40 <-- editieren / zitieren --> Unities abgeben:
CADwiesel Moderator CAD4FM UG
Beiträge: 1968 Registriert: 05.09.2000 AutoCAD, Bricscad Wir machen das Mögliche unmöglich
erstellt am: 05. Dez. 2018 10:03 <-- editieren / zitieren --> Unities abgeben: Nur für silcono
in der Funktion get-3d-pline ersetzt du den code Code: (cond ((= (vlax-get-property obj "ObjectName") 3d) (setq pl3dobj-list (append pl3dobj-list (list obj)) ) ;_ end of setq ) )
durch diesen: Code: (cond ((and (= (vlax-get-property obj "ObjectName") 3d) (=(strcase(vla-get-Layer obj))"DEINLAYERNAME") ) (setq pl3dobj-list (append pl3dobj-list (list obj)) ) ;_ end of setq ) )
in der Funktion get-3D-pline-old brauchst du nur die Filterliste um den Layer zu erweitern
Code: (setq filter '((-4 . "<AND") (0 . "POLYLINE") (8 . "DEINLAYERNAME") (70 . 8) (-4 . "AND>") ) )
------------------ Gruß CADwiesel Besucht uns im CHAT
erstellt am: 05. Dez. 2018 10:04 <-- editieren / zitieren --> Unities abgeben:
